Question about Microsoft Windows XP Home Edition
Computer wont start in safe mode
Desktop computer running on Windows XP pro, servise pack 3.
when safe mode is chosen to boot, it goes through a list of files, then restarts.
its been infected with the "New Win32" virus and needs fixing through safe mode, but just keeps restarting when safe mode is chosen
  • 1 more comment
  • Embem May 21, 2009
    the run feature has disappeared off the start menu. is there any other way to access it?
  • Embem May 22, 2009
    do you know where we can find the "run" feature off the start menu?
    it has disappeared and according to my brother we can't try what you suggested without it
    thanks, Embem
    comes up with an "restrictions" message,
    "operation has been canceled due to restrictions in effect on this computer. please contact you system administrator"
    this is on the administrator account.
    President:
  • 156 Answers
Click On Start---> Run---> MSCONFIG---> click on BOOT.INI --> Then Click On Safe Boot --> Click Apply And Click Ok---> Restart Your system u'll get what u want.......... Temme If u need any help in virus removal...
Plz Rate This Solllution If It Works For u
Posted on May 21, 2009
  • 1 more comment
  • Vick
    Vick May 22, 2009
    Leave Safe Mode Option For Removal Of Infections .... Follow The Links Below And Download And Install These Software And Run A Complete Scan. Do Keep In Mind That U Don't Update These Software's..
    SUPERANTISPYWARE --> http://www.filehippo.com/download_supera... ---> After Following This Link Click DOWNLOAD LATEST VERSION.
    TROJAN REMOVER --> http://www.scanwith.com/Trojan_Remover_d...
    BUT IN CASE IF YOU DON'T LIKE MY METHODS THEN FOLLOW THIS FIRST---
    1) C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe
    2) Open My Computer and Copy & Paste The Step Above In Address Bar Which Has ""My Computer"" In It....
    IF THE ABOVE METHOD FAILED THEN THIS WILL WORK...
    First of all, we need to make sure that the MSCONFIG file is still in
    your drive. Surprisingly MSConfig.exe is not located in Windows or
    System32 directory. Two ways to find where MSConfig.exe is. You can
    either use Windows search to look for *msconfig* or go to another
    computer, use Process Explorer to find the path to MSConfig.
    In the right pane, next to Default, it should show:
    Once you have both MSConfig.exe file in your computer and the registry
    path is set correctly, you shouldn’t have problems running msconfig
    command from Run.
    In addition to the fix above, here’s a very good tool that is able to
    create usable copies of REGEDIT, MSCONFIG and Task Manager which I
    found from Doug’s website. This small VB
    6 utility will create a usable backup copy of Taskmgr.exe, MSConfig.exe
    and Regedit.EXE in a new folder, called C:\EmergencyUtils. The new
    copies will be named Copy_of_Taskmgr.exe, Copy_of_MSConfig.exe and
    Copy_of_Regedit.com.
    As you can see, Process Explorer clearly shows that MSConfig.exe is
    located in C:\Windows\PCHealth\HelpCtr\Binaries\MSConfig.exe.
    Go to C:\Windows\PCHealth\HelpCtr\Binaries\ and check if MSConfig.exe
    file is there or not. If it’s not there, you can copy it from another
    computer to the Binaries folder or if you only have Windows XP CD, open
    a command prompt window, insert your XP CD into the drive and enter the
    following command: (assuming D is your CD drive and C is where your
    Windows is installed)
    EXPAND -R D:\I386\MSCONFIG.EX_ C:\WINDOWS\PCHEALTH\HELPCTR\BINARIES
    That should restore MSConfig.exe to your Windows. IF MSConfig.exe is
    already there and you still can’t launch MSCONFIG from Run command,
    then the reference to the path within the registry may be wrong. Check
    this location in the registry:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\App Paths\MSCONFIG.EXE
    Need Any More Help Then Tell Me...
  • Vick
    Vick May 22, 2009
    HOLD THE WINDOWS KEY DOWN AND THEN PRESS R KEY AND CHECK WHETHER THAT HELPS OR NOT....
  • Vick
    Vick May 22, 2009
    The only easiest way i see now is to FIRST MANUALLY REMOVE INFECTIONS from your system because the infections is blocking windows registry commands to run and that is the reason why run is not coming up..
    Try following..
    Create a new User Profile and see if RUN is coming up or not....
    If yes then v r done with the solution and if not then
Pass word of my window
Try restarting your computer. While the computer is restarting press and hold down the f8 key untill you are prompted with a black and white screen that has the option to boot in safe mode. Select boot in safe mode, Once your "safe mode" desktop appears go to your user accounts an change your password. Hope this helps
Jun 21, 2010 | Microsoft Windows XP Professional With...
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Cannot find shooter.exe
Sounds like a Malware message. Boot your computer to the desktop, or if you are unable, boot to Safe Mode (F8). Download, install and run MalwareBytes (MalwareBytes.com). Hope that helps.
Jul 23, 2009 | Microsoft Windows XP Professional With...
My system restart problem
Sounds like a hardware or heat issue. In safe mode your computer is using just minimum resources. Check the temp of your processor, and make sure all cooling fans are running. You can enter bios and check hardware monitor to see the temps.
Apr 25, 2009 | Microsoft Windows XP Professional With...
Restarts computer in loop at 5-8 minutes of boot
Please try install XP SP3 in safe mode. Then check whether you have the latest Graphics Card Driver. It seems like some driver issue as it reboots only in Normal mode. Since safe mode runs on minimalset of hardware drivers.
Secondly, there may be a corrupt file that caused reboot. Spend a night and schedule bad sector check - Right click on system drive, Tools tab, Error Checking -> Check Now, tick both boxes then Start. It will schedule scan on next reboot. Then reboot to confirm it starts checking HD.
Apr 24, 2009 | Microsoft Windows XP Professional With...
Forgot password
Reboot the computer. Press and hold the f8 button. Select safe mode from the menu. You should be able to see the admin login. Then you can make the changes.
Nov 22, 2008 | Microsoft Windows XP Professional With...
Desktop doesnt boot.
If you have a windows XP recovery CD, try running that at boot.
also, try pressing the f8 key to boot windows in safe mode.
it sounds like a corrupted OS install: if you can't recover, you may have to reformat your hard drive and reinstall windows.
Mar 29, 2008 | Microsoft Windows XP Professional With...
Give me
Please reinstall your windows...
Sep 26, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Home Edition Logo
166 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
