Question about InSTEP 10K Ultimate Double 11-KA285 Jogger
Upholstery has midew can it be taken off and cleaned?
Mildewed Upholsatery
Try washing with bicarbonate of soda mixed to a paste ,apply leave overnite then rinse off well .If material is stiff and hood or apron seems to have shrunk then spray several times with solution of mixed up fabric softener then gently stretch back to fit and let dry in place .
Posted on Sep 01, 2013
  • 127 Answers
Unfortunately there is no way to get mildew of anything you can try wasing it but it will still be there,you get get some seat covers to hide it.
Posted on May 21, 2009
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Odor problem
clean the front gasket on the door with Tilex, they get mold and midew, also run a tub of hot water with some Tilex brand mold and mildew remover through it, then run a second washer tub to clean Tilex completely out, u will need to do this about once a month, and yes all fron loader have this odor problem.
May 20, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Cleaning internal humidifier
Try using vinegar and distilled water.
If this does not work try using a little bleach and water. Repeat till mildew is gone.
Rinse thoroughly Again & Again.
Everyday humidifiers should be cleaned.
After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
Mold & mildew will cause you to get very sick.
If the mildew does not go away replace your unit.
May 19, 2010 | Humidifiers
We have mildew in the rubber gasket behind the front door
use a good mildew cleaner on gasket the gasket gets wet from when clothes are taken out and drip on gasket mildew grows on damp/warm surfaces
Sep 26, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Brushes not turning
your belt could be turn of or it is jamed inside ,take of the buttome and check for those two things.if my info was of any help to you please leave a comment ,thankyou.
Sep 02, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bad smell after replacing heater and evaporator
It sounds like your A/C drain is blocked and mildew is building up this is a common occuance during the summer. Most Dealerships have a chenical that you spray into your heater case that will remove this oder.
Aug 22, 2009 | 2002 Jeep Grand Cherokee
DC14 Animal Vacuum Smells Like Mildew When On
try clean with baking soda clean all the filters with and dry out hot sun so midew dosent get chance grow in the filter
Jul 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I shampoo my upholstery
Instructions are HERE. Try shampooing on a part of a furniture that is not visible much... sometimes this may not work well.
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a Maytag Neptune Front Load Washer. It spins the water out of my clothes good, but when the Washer stops and I take my clothes out, when I spin the inside by hand I can hear water between the drum...
water sound when spinning by hand totally normal, they use water as a counter balance, built into tub assy. as far as the mod/midew odors a few things things can help, first make sure youre using an HE detergent(HE detergent specially formulated for front loading machines) odors can be attributed to excessive amounts of detergent not completely broken down during the cycles, leaving the door ajar between cycles will also promote better air flow through the unit. and lastly using this product. new to the market made just for the front loading washers .
http://www.affresh.com/home.jsp
Mar 23, 2008 | Washing Machines
InSTEP 10K Ultimate Double 11-KA285 Jogger Logo
130 people viewed this question
Top InSTEP Baby Gear Experts
Jennifer Rock
Jennifer Rock
Are you an InSTEP Baby Gear Expert? Answer questions, earn points and help others
