Repair dl08ha00019 dvd
My murphy Tv/Dvd player has this part installed and whichever disk is inserted it will come up "No Disk" Shall I need a replacement for this part to install?
  • 899 Answers
SOURCE: disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Posted on Jan 15, 2009
jmgldsmth
  • 1906 Answers
SOURCE: It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Posted on Apr 28, 2009
konzzz
  • 255 Answers
SOURCE: DVD Player keeps reading no disk even though there is inserted in the slot
try cleaning the lens, first.
Posted on May 28, 2009
  • 53 Answers
SOURCE: Have the Samsung DVD-AR650. When I insert a blank
My last recommendation, before seeking a replace or repair; would be to run a cleaner disk. Optical drives can be affected by dust on the optical block lens or dust on the disk itself. Sometimes a dirty lens can even cause your drive to eject the disk when you try to read it. It is recommended you clean your lens every 3 months in an office environment, or once a month if you use the drive in an industrial environment. They range in price from $3 to as high as $130. In such an
Posted on Jan 07, 2010
SOURCE: Clear Play DVD player
I just encountered the same problem. We've had our player for quite a while, but it seems like there ought to be a way to fix it from home. I don't mind taking it apart if that is needed, but I'd can't just buy a new one each time!
Posted on Apr 13, 2010
Incert dvd read out sats NO
Hello
This usually happens when the DVD or laser lens pick-up has become dirty.All you need to do is
1. Check the disk for scratches.
2. Make sure the disk you are using fit the correct format specified by your DVD player.
3. Clean the laser lens with a DVD laser cleaning disk.
4. Insert a correctly formatted undamaged disk into your player,listen to see if it begins to read the disk,if it continues to make no sound.
5. Open the DVD player carefully and clean the lens with isopropyl alcohol and cotton swab.
6. If none of these solutions works out then a professional repair technician will be able to tell you if fixing your DVD player is worth the money.
BEST OF LUCK
Jul 13, 2010 | Toshiba SD-K760 DVD Player
In spite using DVD-R disks with the specified logo (in the case, Memorex and Sky), as I insert them in the recorder, it formats the disk but doesn't record anything on it and, when I try to eject the...
?Ÿ???¾?±?»?µ?¼?° ?µ ?²??µ?¾?±?? . ?¢????±?²?° ?´?° ??µ ??¼?µ?½?¸ ?¿?¸??°?????°???° . ?¢? ?µ ???¾?¼?¿?Ž???Š???½?° , ?¾?¿?¸???²?°?¼ ??µ , ?½?¾ ?½?µ ?µ ???°?·?¿?¾?·?½?°?²?° . ?¢????±?²?° ?´?° ??µ ?½?°?¼?µ???¸ ?½?°???¸?½ !
Nov 03, 2009 | Sony RDR-HX1000 DVD Recorder
Not reading disk
i think your dvd player lens is no more able to read the dvd content. You may change the dvd lens from hardware repair center or buy new only.
Oct 28, 2009 | Cycling
Dvd does not read disk...says "no disk"
Hi there! I would return it under warranty. Do not even think of repairing this as it is a manufacturing fault and you should not have to pay extra to have it seen to. Some suppliers have a 7 - 14 Day exchange warranty, so may not have to wait for a repair. Best Wishes and Good Luck, JUS004
Aug 22, 2009 | Memorex MLTD2622 26 in. LCD TV
Disk rotating and a message "invalid disk"
Jan 10, 2009 | Coby DVD-211
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 02, 2009 | Coby DVD-209
Try to use a different dvd because that one might not have been burned or made in the right format. If that doesn't work, then try blowing on the laser just in case there is dust on the lens causing it not to read the dvd properly. If that doesn't work, then you might need a new dvd player.
Oct 23, 2008 | Coby DVD-283 DVD Player
Problem of COBY DVD 283 player
return it for a different one
Jul 01, 2008 | Coby DVD-283 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Not playing DVD
i have coby dvd 283 player , its new but i don't know why it is nt playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do
Aug 23, 2007 | Coby DVD-283 DVD Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
