Question about NEAT Receipts Mobile Scanner
Trouble installing Component SQL Server Compact 3.5 SP2 has failed to install with the following error message: "This installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this is a valid Windows Installer package. "
2 Suggested Answers
prashant2012
  • 1127 Answers
SOURCE: Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
Posted on May 24, 2012
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
I isntalled P6 and SQL with SP2 package in the same order one by one. There was no problem in installation. But, after installation I am not able to open the P6 - I get an error message that the license is...
hey there i dont know about sql. change your system date (only year) on to previous then open your software. if this does'nt work then change your operating system if u're using xp then change it to win 7.
Nov 28, 2010 | Computers & Internet
Hay Bahratt, I have uninstalled the 3 SQL programs in the control panel a few times with no effect on the issue. I didn't try moving directory C:\Program Files\Microsoft SQL Server\MSSQL to another...
If you have removed it from control panel, its done. You just have to clean up any left over registry entries using CCleaner and then try installing again
http://www.ccleaner.com/download
You may also want to check out this microsoft link if it doesn;t work
http://office.microsoft.com/en-us/help/HP011128601033.aspx
Jan 10, 2010 | Computers & Internet
Error installing MS Office pro 2007 with BCM
Uninstall from control panel the following:
Microsoft SQL Server native client
Microsoft SQL Server Setup Support files
Microsoft SQL Server VSS writer
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
Jan 10, 2010 | Microsoft Office Professional 2007 Full...
Im not able to instalthe primavera p6 on my new hp lap windows 7
Before installing primavera p6, check whether any SQL databases with the same name exists. Uninstall the SQL if the databases created during the previous failure installation of primavera p6(go to add or remove programs to uninstall). After uninstallation of SQL express, try to run installation files for primavera p6 will solve your problem.
Revert back for more assistance.
Dec 26, 2009 | Computers & Internet
When booting the system the following error message appears: SQLDUMPER failed initialization
the uninstall tool vs_uninst.exe located at http://download.microsoft.com/download/0/a/a/0aacd9c1-a0c5-43ab-a428-0ee440d4472c/vs_uninst.exe.
this error usually occurs when removing certain Microsoft products, or when using the SQL server. Here is a few articles which may help you correct your issue. First, it is a forum where an individual has a similar issue, and the help offered:
http://www.sqlteam.com/forums/topic.asp?...
Next, a Microsoft Knowledge base article on the SQL sqldumper utility, and some troubleshooting techneques:
http://support.microsoft.com/kb/827690
The next page is the SQL tech support and has different errors which can be generated. Look down the list and see if you can locate your particular error and when/how it occurs:
For SQL 2000:
http://www.gridview.org/kb/SQL2000/defau...
For SQL 2005:
http://www.gridview.org/kb/SQL2005/SQLSe...
May 13, 2009 | Microsoft Windows XP Professional for PC
Webexception
Your program that is using the .net compact framework is the one failing (not catching an exception), but because you haven't yet installed the optional resource strings for reporting error messages in .net cf apps (a big mistake by the .net cf team by making that optional), you're not seeing the real error message. You're only seeing the "an optional resource assembly containing it cannot be found". Install System_SR_ENU_wm.cab on the device, then reproduce the error. This time you will see a better error message.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk over WLAN for warehouse devices - FREE for up to 5 users)
www.radicomm.com
May 13, 2009 | Symbol MC70
I am unable to install sql server 2005 in windows server 2003. how to upgrade this to windows server 2003 sp2(x86).
You can download Windows Server 2003 (SP2) from following link:
http://www.microsoft.com/downloads/details.aspx?FamilyID=95ac1610-c232-4644-b828-c55eec605d55&displaylang=en
Thanks.
Mar 03, 2009 | Microsoft Windows Server Standard 2003 for...
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Unable to create database from within VWD 2005 Express
try to complete uninstall .net framework and install it again or get the latest copy of .net framework to install 3.5 latest version already available for download
Dec 01, 2008 | Computers & Internet
NEAT Receipts Mobile Scanner Logo
Top NEAT Office Equipment & Supplies Experts
Steve F
Are you a NEAT Office Equipment and Supply Expert? Answer questions, earn points and help others
