Question about Dryers
The dryer does not start, it indicates that it i full of water even if the tank is empty
  • lars_eriksso May 21, 2009
    Sorry it is tumbling drier which contains a water collecting tank
  • 111 Answers
Why does your dryer have WATER in it? And why is there a tank? Are you talking about a washer? LOL
Posted on May 21, 2009
Zanussi ZDC8202P-WH. Only 10 days old. It stops halfway through the cycle with the 'water tank full' indicator coming on, but tank doesn't need emptying. It is in properly.
Return it back to the place of purchase and buy a different brand of dryer. Try Whirlpool or Sears Kenmore. You should have much better luck with these name brands.
Dec 01, 2015 | Zanussi Dryers
The full tank light remains on even though the tank is empty. Is there a sensor which stops the dryer from restarting
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
The tank capacity is about 3.5 lt., enough for a drying cycle.
- Remove the screw (1) which secures the support micro and use a screwdriver for the two hooks which secure it to the sump.
- Lift them simultaneously and unthread the micro support towards outside
Putting upside down the support you can access the floating microswitch.
25069013-hcssld2gpo2sm22yg24xoxcy-3-9.jpg Inside the sump there is the float.
To extract it rotate the float 90° clockwise as shown.
Lift it up, rotate it towards outside and extract it.
While reassembling the pump, the float and the tank microswitch, repeat the same operations backwards, paying attention that when the micro support is remounted it is necessary to use a screwdriver in the fissure (indicated by the arrow), to lift the micro lever and lean it over the float (if this operation is not carried out the lever of the micro comes up alongside the float (it deforms) and the two components do not function anymore.
25069013-hcssld2gpo2sm22yg24xoxcy-3-20.jpg Dado
Sep 06, 2014 | Zanussi Dryers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Empty water light flashing on hotpoint ctd40 dryer even with no water in it can you help
this could be just a sticky switch staying stuck on, telling the dryer it has a full tank try soaking the switch in switch cleaner or wd40 may work
Jul 23, 2010 | Hotpoint Dryers
I have hotpoint consdenser dryer model ctd00p - not drying clothe
if the water tank is empty you probably need a new thermostats .
Feb 11, 2010 | Dryers
Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Dec 31, 2009 | Hoover Dryers
Indesit condensair dryer
I have had a similar problem, my wife tried drying clothes that were too wet, causing the machine to flood. Even though she emptied the tank, the empty water light was always on!!
What I did was take the electrical plug out and tip the machine to one side, you probably will find there will be a collection of water in the base, which will leak out. Once you think you emptied it, plug it back it back in and try it.
It worked for me!
Stooooman
Aug 15, 2008 | Zanussi TC180W Electric Portable Dryer
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Dryers Logo
83 people viewed this question
Top Dryers Experts
