Question about HP Computers & Internet
Deleted cd-rw/dvd-rom driver
I deleted cd-rw/dvd-rom from my computer by accident now my computer don't recognize it I tried disconnecting and conecting againg but my computer dont read it neither where in the web can i find the driver or how can i fix it my computer is an Compaq presario sr1910nx and i don't have a system restart point neither that I can take it back to a previous date
I talked directly with HP about your problem. Unless you can find the driver in system32 or your windows installation disc, you will likely have to reinstall windows. Prepare a backup of all important files on that desktop though, because data loss is possible.
Posted on May 21, 2009
All of a sudden, my LG GH22LP20 stopped recognizing cd's. I don't have problems with dvd's, they are read and recognized well. I can not burn a cd
thats strange usually if it reads and burns dvd's it should be the same with cd's
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 11, 2011 | LG GH22LP20 DVD±RW Burner
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I have an LG GH24NS50 DVD RW and I added another DVD RW with lightscribe - I was loading the updated firmware to my new lightscibe drive but incorrectly loaded to my LG drive. Now Windows does not...
make sure that the dvd-rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 06, 2011 | LG GH24NS50 DVDRAM Burner
Drive not recognized driver missing or currupt
a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Oct 30, 2010 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Windows Vista recognizes the Memorex DVD- RW multi recorder w/Lightscribe device and the Lite-On CD-ROM device, yet fails to recognize the drivers sending an error code 10. It says the device is unable to...
You need to have a software driver download for the Memorex DVD-RW and Lite-on CD ROM. You can have it from the Internet. Just type at the Search engine blank (Download for driver of Memorex DVD-RW). Upon reaching the site, Choose the one with Windows Vista OS. Then, thereafter you can get the download for Lite-on CD ROM. After having the
download, go back to your PC menu and open the
download to install it. Once installed, test it. And job
well done.
Nov 27, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Driver not showing on my computer
Try the following tips;
Install the driver on device manager, if you have accidently uninstalled it.
Can you see the DVD +/- RW on “Disk Management” If yes it should accidently the partition should have been deleted? Please partition it with a volume label (DVD +/- RW) normally drive D.
Or Try a system restore to a previous date when the computer was working fine. Please backup all your current DATA as you may lose them.
Good Luck!
Sep 02, 2009 | Sony AD-7590S DVD±RW Dual Layer Burner
When in ''MY COMPUTER'' - CD Drive (E:) was droped into DVD-RW (D:
Try uninstalling the drivers in device manager, shut down, reboot and Windows should find both devices, it might ask for your windows disk to install drivers or search online to install them
Jul 27, 2009 | Computers & Internet
Computers & Internet Logo
166 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
