Question about Toys
2008 RZR battery not charging - Toys
2008 Polaris Rzr has a known issue with the under-seat location of the voltage regulator. In that location it can't get enough air flow to keep cool. When overheated it protects itself by shutting down. During these periods you are running off the battery instead of the stator & regulator--this is what kills your battery and strands you far from the road.
Polaris corrected this in 2009 and newer by moving the regulator up front behind the grille but did nothing for 2008 owners. You can cut/splice an extension or buy one online. Google "Rzr regulator relocation".
Posted on Jan 22, 2014
I have Polaris rzr silver replaced mother board and accelerator pedal but I have no power an battery is charged
RZR ® XP 1000 EPS FOX ® Edition Turbo Silver - Polaris
www.polaris.com/en.../rzr.../rzr-xp-1000-eps-fox-turbo
Polaris IndustriesFeatures for the 2015 Polaris RZR XP 1000 EPS Fox Shox Edition Turbo Silver. ...Parts & Service. Go ..... Designed specifically for extreme performance, the Polaris ProStar® 1000 engine features 999ccs of big bore twin .... RESOURCES; Manuals ·Parts Catalog · Apparel & Accessories Catalog · Brochure · Careers.
Aug 26, 2015 | Toys
Battery is charged but wont run
Check that the wires for the motors on the rear tires are connected. If they are connected check with a multimeter and make sure that they are showing 12-13.8 volts
Apr 26, 2015 | Polaris Ranger RZR Ride on Toy
2013 800s rzr misses at low speed
Solid state ignition has a capacitor that must charge and when the right time comes a SCR will dump the charge into the coil to make a spark. There is a minimum voltage that is required to trigger the SCR and at low RPMs that normally is close to being not enough. Most likely you will need to change out that CDI ignition or check the coil in the magneto, it may need to be adjusted closer to the flywheel.
Sep 20, 2014 | Polaris 2013 RZR S 800 Orange / White LE
2012 rzr4 800 will the stator charge at all if its bad
A typical, fully charged & unloaded 12 volt lead acid battery should indicate about 12.6 V. Check the voltage / percent charge chart below:
Volts - Charge
11.7 - 10%
11.9 - 20%
12.1 - 30%
12.25 - 40%
12.35 - 50%
12.45 - 60%
12.5 - 70%
12.6 - 100
A fully charged that is only about 12V indicates a a problem with the battery - dead / shorted cells, etc. You can always remove the battery and have it tested at Autozone or similar auto parts stores if you're unsure. From the info you've provided - my guess is that the battery is "done"
I hope this was helpful - good luck!
Apr 01, 2014 | Polaris 2013 RZR 4 800
When running the battery is not charging itself
the batteries don't charger themselves, they need to be charged by an external charger after use
Mar 27, 2013 | polaris ranger rzr
Toys Logo
205 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
