Question about Microwave Ovens
Mvh110e installation or removal
I have an older model Amana microwave Radarange mvh110E and wondering what are the watts? Can you help? Janie Staunton, VA societydame@verizon.net
see the definitions and how to calculate: God bless you
The Watt is a measure of power or how much energy is released per second. It can be shortened to W.
1 Watt can be written 1W.
We can calculate the power released in a bulb by multiplying the voltage in Volts across the bulb by the current in Amps flowing through the bulb (W = V x I).
Oct 21, 2013 | Emerson MW8106W Microwave Oven
Tip
How to uninstall program from my DELL computer
Questions people asked:
1 How to uninstall program that’s not showing up?
2 I go to add/remove programs and want to uninstall program. It says “error, can not delete the program”, how can I remove it from my DELL computer?
3 I recently install McAfee and my computer gets a Blue Screen, Should I uninstall it? How to remove it from Control Panel?
You may face stubborn program of uninstalling an unwanted program especially it is an anti-virus.
How to remove corrupt programs from your computer in one minute? You can get the best solution to remove a program completely from your PC.
Add/ Remove Programs utility usually helps you remove programs from your computer. Unfortunately, it can only find common program install on your computer. It can not show hidden programs and some malicious programs such like windows messenger, vista protector, Norton anti-virus 2006, etc.
You can not remove anything if you uninstall using Control Panel. Every time you install a program, your registry entries will be modified. The residue can be the causes of Blue Screen, computer freezing, DLL error and computer slow. If you want to remove programs completely, you should also remove associated registry entries. It is also the best solution to remove corrupt programs.
Get rid of programs which combine well with the operating system:
Troubled with uninstalling programs? Don’t worry! You can solve it in one minute. ErrorFix integrate with Windows registry fix tool, uninstaller, invalid file removal and IE restore program.
Download this excellent uninstaller now.
With this software, you can forcibly remove a program even it is running. Why not experience this wonderful software? You don’t have to get more computer savvy.
on May 26, 2010 | Microwave Ovens
Having trouble removing front grill to install filter..removed top screws but grill will not come loose
Just installed a GE Spacemaker - my instructions tell me to remove screws and then slide grill to the left and then remove. Have you tried that?
Jan 05, 2010 | GE Spacemaker JVM1540 Microwave Oven
Can't install activated charcoal filter
To get to the filter you need to remove the 2 screws that are on top of the micro holding the grill on. Once the screws are removed you will see the filter. Also here is a manual if you need. Page 37 tells you how also.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0307022.pdf
good luck
Oct 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
How to install charcoal filter in ge microwave md# jvm1870 sk04
From the owner's manual, page 37:
To remove the charcoal filter, disconnect power at the main fuse or circuit breaker panel or pull
the plug.
Remove the top grille by removing the screws on top of the grille that hold it in place and sliding the
grille to the left (opening the door makes grille removal easier). Slide the filter towards the front of the oven and remove it.
You can download GE owner's manuals and installation instructions here.
You can order new filters by entering your full model number here.
Sep 19, 2008 | Microwave Ovens
Amana micorwave
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
