Question about Mitsubishi WS-65511 65" Rear Projection Television
Tv turns on manually, but auto flips through channels and you can't use remote
T.V. will not turn on with remote.  When turned on manually, there is no volume control.  The channels automatically start flipping through channels lowest to highest, but you can't use the remote to control anything.  You can't manually change the channel up, only down.  You can't change the device without the remote.  It's like the t.v. doesn't recognize the remote anymore.  This all started by just trying to change the device mode to vcr, to watch a tape.
  • Anonymous Mar 21, 2014
    im trying to tune my tv to my xbox but have no remote ive used the buttons on the side but it wont do anything when i select auto or manual tune
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Posted on Dec 26, 2007
How to tune channel when channels are locked?
The Sony KV-36HS510 has an Auto Setup function for the channels.
1 Press POWER to turn on the TV.
2 Press TV FUNCTION on the remote control.
3 To continue running Auto Setup, press CH+. To exit Auto Setup,
press CH-.
Auto Setup automatically creates a list of receivable channels. When
finished, the lowest numbered channel is displayed.
To reset the TV to factory settings
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
Apr 14, 2016 | Sony FD Trinitron WEGA KV-36HS510 36" TV
How do i set the chanel to 3 so that i can hook up cable with out a remote
Most sets it is impossible and will skip channel 3 and input. You will need to buy a cheap universal remote.
Feb 27, 2015 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Technika tv
You might need to set up the channels in the menus. Try auto scanning the channels. Read you operating manual on setting up the TV.
Oct 23, 2013 | Televison & Video
TV flips through channels at 2 channels per second.
It sounds like a button is stuck or bad. I would spray some electrical cleaner on the buttons 1st. If that don't work, the switch is probably bad.
Jul 23, 2010 | RCA F32645 32" TV
I have a Dynatron DYN100Z remote I need to set it for a Symphonic TV . It has worked on this TV before. I lost the code.
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on. 3. Click the (+) Channel button once each second, until the TV responds by flipping a channel. 4. One the channel changes, press the, "ENTER" button. 5. Code is saved!
Jan 07, 2010 | Televison & Video
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
Can not turn on tv.
Just press the buttons on the TV randomly, sometimes this combination works in starting the TV w/o a remote. After that use the remote for the dish to flip channels, but you will have to set the sound manually from time to time.......sodeep
Jun 13, 2009 | JVC AV-32120 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Remote won't work
reset the default setting go to menu button and manualy do this.....
Jun 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
219 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
