Question about Boating
Suzuki outboard repair
90hp suzuki not pumping much water. done low hours
  • 11 Answers
SOURCE: suzuki 4hp two stroke impellar
Dropp the lower unit, should be only 4 bolts holding it on. Impellar housing should be located right on top of the lower unit. four screws it the housing slides off the shaft, insall in reverse order with ne gaskets, make sure you re- align the waterhose/pipe from the lower unit back to the head
Posted on May 01, 2009
  • 187 Answers
SOURCE: outboard motor idles but will not speed up
You really have to blow out the jets to clear any varnish left over from lay up.
Posted on May 13, 2009
  • 6 Answers
SOURCE: CHANGE WATER PUMP IMPELLER FOR EVINRUDE OUTBOARD MOD# E28ESLETD
Crowley Marine Boat Parts & Diagrams have diagrams of all the components, and the catalog is easy to go through to pull them up, OEM and other brands, no cost for the images.
Posted on Jan 21, 2010
SOURCE: 90hp 4 stroke suzuki outboard how do i reset the oil alarm?
TO RESET:
1. TURN IGNITION KEY ON
2. PULL OUT THE EMERGENCY STOP BUTTON 3 TIMES IN TEN SECONDS, A SHORT BEEP WILL BE HEARD IF CANCELATION WAS SUCCESSFUL. TURN KEY OFF AND PUT EMERGENCY STOP LANYARD BACK ON ITS BUTTON
Posted on Apr 15, 2010
muffteck
  • 202 Answers
SOURCE: looking for torque specs for complete engine
get a manuel you will need more than torque spec. different lubs go in different places
Posted on Mar 16, 2011
Just changed the impeller on my 2012 Yamaha 90hp outboard, but no water coming out of the tell tale. what could be wrong?
howd the pump drive shaft nib look when you replaced the old one ??? if it was worn round and not "D" shaped it wont drive the new pump
Aug 12, 2016 | Boating
How to install a evenrude outboard water pump
the exhaust ports start from the side of the engine block 2hp -90hp then v4 and v6 and v8 are between the v blocks ! from there they go down the leg unit , top rear of leg have an outlet for tickover then the main outlet is either through the prop or above it on small or old type engines !
May 09, 2014 | Boating
Color codes for guages on a 1994 90hp nissan outboard engine
Normally All Engines Are Color For Color,Sorry Do Not Have Diagram
Mar 19, 2013 | Boating
Evinrude 15HP Outboard - Vent Holes
have a problem , check impeller pump
Sep 07, 2017 | Boating
Can a 1987 90hp johnson force outboard engine be run in saltwater
Yes of course but they need flushed with fresh clean water after doing it .
May 23, 2010 | Light Outboard Motor Boat Bass Fishing...
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
I have ordered a service manual for my older model Suzuki DT16 outboard motor, where is the water discharge located, I don't see any water coming out ?
I've got a 1981 DT16 with a broken starter pinion. Did you solve your problem? Mine is for sale with very low hours.
Jun 21, 2009 | Sport & Outdoor - Others
TO RESET:
Apr 11, 2009 | Sport & Outdoor - Others
Boating Logo
21 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
