Question about Husqvarna Designer I
Husqvarna Viking Designer 1 keeps breaking needles
I will start to embroider and it's working fine all of a sudden clunk, clunk the needle breaks in half or in three. This is happening all the time now.
I have the floppy Designer 1. ????? Help
  • Anonymous Mar 16, 2014
    how do you put a needle plate back on a Husqvarna Viking E10?
    Problem Solver:
  • 7 Answers
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
Posted on Jun 19, 2009
Thread keeps breaking using husqvarna
try these suggestions
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 30, 2012 | Husqvarna Sewing Machines
Designer 1 se needles keep breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
Feb 09, 2012 | Husqvarna Designer I
Husqvarna 3610 doesn't pick up lower thread
Hi, Check to see if needle is bent. If the needle is bent it will not work well and soon it will break.
Replace the needle. Also lube the moving parts on your machine. (fine oil) sold in most sewing centers.
Jul 24, 2011 | Husqvarna Viking 1
Designer SE hit pin head while sewing.
did you take out the whole bobin case and see if it has a piece of the broke needle in there?
Jul 22, 2010 | Husqvarna Viking 1
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Viking 1+--Thread breaks during embroidery
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Mar 23, 2008 | Husqvarna Viking 1
DESIGNER SE breaking needles
Sounds like the needle to hook gap needs to be adjusted, i.e. the needle is striking the hook when in the lower position. As the needle becomes dull, it probably bends slightly causing more contact and hence breaking. I would try another dealer if you think that might help., You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 16, 2008 | Husqvarna Designer I
Sewing Machines Logo
534 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
