Question about Gaggenau Cooktops
Gaggenau 200 Series?
We purchased a home built in 1991 with an electric Gaggenau cook-top. It has four burners, 2 on each side of a 4-burner electric grill in the middle. 3 of the 4 burners are not working properly, taking up to 45 minutes to boil 8 cups of water. The house came with a home warranty, but this is the third time I have had their technician out and he says he has done all he can do. Meanwhile, the warranty company has told me that "this is to be expected in an older cook-top! I'm looking for average temperatures to be expected from these cook-tops to prove it is broken, not just old. Thanks.
    Scholar:
  • 102 Answers
If it is similar to the VE260 model, this induction type of cook top is very old. 22 - 23 years if it came with the home when it was built.
I can only offer basic suggestions of which you already probably know.
These induction type cook tops rely on the pan or skillet to be magnetic like stainless steel. If the bottom of the pan has any buildup of residue, this will dramatically reduce the efficiency of the unit.
If the pans are immaculate, then the electronic elements that produce the magnetic induction to heat the coils must be weak. As old as the unit is, it is probably not feasible to have 3 of the elements repaired....
A new top can be purchased much cheaper. Consult Consumers Reports for unbiased product reviews for your best reviews. As a final suggestion, find someone who is qualified to use an electrical multimeter to read the current on both sides of the power receptacle to ensure that your voltage is 230V. A loose connection on the receptacle can cause the elements to have the same result.
Although I can imagine you have already done everything above, I just wanted to send you what I can offer.
Posted on Jan 02, 2014
3 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Posted on Mar 24, 2009
heatman101
  • 43501 Answers
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Cook top burner knobs all 4 not able to turn
Just to be clear, non of the 4 burner controls/knobs will turn ? You are familiar with this unit are you ?
Typically you must push down and turn to activate them.
Let me know if that is not the solution.
Good Luck :)
Oct 29, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Broke glass on electric genn-air
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Gaggenau Cook-top VG 352-812 problems
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help.
Claus.
Jun 08, 2008 | Cooktops
Burner goes out when cabinet door is opened!
i haven't worked on one of these models hands on but on most you can pull the burner **** and look inside you should see a tiny ***** in there hold the outer piece with a pair of pliers and take a tiny screwdriver and after turning the burner on turn the ***** to adjust the flame just enough so the suction doesn't blow the flame out on the lowest setting
Mar 08, 2008 | Cooktops
Replacement dual burner Gaggenau CK594
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Jan 15, 2008 | Gaggenau 47 in. CK 594 Electric Cooktop
Gaggenau VG-352-812 Cook top
You should be able to go online to Gaggenau and in the service area there is a link for order parts
Jan 03, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Cooktops Logo
154 people viewed this question
Top Gaggenau Cooktops Experts
paulcarew
Tall Tiger
Tall Tiger
Dave Lammas
Level 1 Expert
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
