Question about Gateway DX4870-UB20P Core i3-2120 3.3GHz 6GB 1TB PC with HDMI & WiFi-N
Wont power on, power button not working - Gateway DX4870-UB20P Core i3-2120 3.3GHz 6GB 1TB PC with HDMI & WiFi-N
  • 22 Answers
Of course do the usual things...check that the power strip is turned on or the computer is plugged into the wall, etc. Make sure it's firmly plugged into the back of the computer also. If those check out, and still no luck, you'll have to get into the computer itself. Looks like the panel on the left side comes off on that model. The power supply is at the top and back of the computer and has all the wires coming out of it. Make sure that the widest bunch of wires coming out of it (20 or 24 wires) is going to the motherboard and is plugged in firmly and all the way down. Also, there is a small group of cables that are only yellow and black (4 total wires) and should plug into a place to the upper lift of the processor, which is where the fan is in the middle of the motherboard. If those are snug, try once more. (Good idea to unplug the power cord from the back of the PC while doing this, just in case.) If still nothing, check to make sure the small wires coming from the front of the case to things like the power button are plugged in firmly. They will probably be plugged into pins on the bottom of the motherboard (usual location). If that's good and none were loose or raised up (if so, try powering it on again afterwards), you may have a dead power supply. If you don't get any fans spinning or lights, you can try one final step, though it's not necessarily indicative of a good power supply if it works. Unplug all of the connections coming from the power supply (going to the motherboard, hard drives, etc.). Once they're all loose, take a paper clip or piece of small wire or something and use it to short the green wire (on the biggest plug that was going into the motherboard) to any of the black wires (just one will do). You might want to use pliers or something for this, though I've never been shocked or anything. Make sure you plug the power cord back into the power supply before doing this as well. So, once shorted, if you don't see the fan spinning on the power supply, it's probably dead and will have to be replaced. If it works, then it may still be good and could be the motherboard possibly. However, I've seen bad power supplies run fans and such, but not be strong enough to run the whole thing. To rule out the motherboard, you basically need to either test the power supply in another computer (if you do, make sure it's comparable power-wise in watts to the other one), or get another power supply and try it on yours. Someone may have a better idea for that, but that's how I do it. Hope this helps. Let us know how it goes.
P.S. Obviously, if this is more than you want to tackle, you'll have to take it to a place that can do this for you. Statistically speaking, this problem is usually a power supply issue more times than not in my experience.
Posted on Jan 02, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 75 Answers
You probably have a bad power supply. They are very easy to replace. You can find instructions on the internet. You can usually remove the left side panel (as you look from the front) with a couple of screws and slide backwards. The power supply will be held on by 4 screws at the back. Remove all the connectors from the motherboard (probably one long one and one smaller one) and from the hard drive and DVD drive. Take it to your local computer store and get a replacement of the same wattage or higher.
Samsung tab 3 10.1 CE0168 Wont charge or come on ?
have you tried a hard reset?, take battery out and disconnect from power supply then hold power button for thirty second then replace battery and try to power up else hold power button and volume down for 30 secs need to keep battery in for this one, if they dont work you need to contact samsung to get it repaired.
Feb 06, 2017 | Samsung Tablets & eReaders
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
HP mini 110 wont power up the screen. The power buttons on the front are lit but the screen wont power up.
While the Mini is on, try holding the power button down for 4 seconds, then power back up. hopefully this hard reset will work.
Jan 14, 2011 | HP Mini 1000 Netbook
The jukebox powers up but the buttons wont work
Is this a CD player or 45RPM? Is the display lighted? What is the display showing? The answers to these questions will help narrow down the problem. For additional assistance please email Rod Stebelton, tech@wurlitzer-ohio.com.
Nov 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wont turn on charged it it still wont turn on ,
Try holding the power button while plugging it in. Also try holding the power button while wiggling a mini screwdriver in the reset hole
Oct 15, 2009 | Navigon 7100 GPS Navigator GPS Receiver
My sansa wont shut off
its called pushing the power button
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
Gateway DX4870-UB20P Core i3-2120 3.3GHz 6GB 1TB PC with HDMI & WiFi-N Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
