Question about Krups BeerTender B95 Beverage Dispenser
Unit is freezing the beer
I've had my unit for 1.5yrs,the temp light is not cutting on, and the unit constantly runs which is now freezing the beer
LG Model: LWHD1500ER - I would like the unit's compressor to remain on constantly. The temp guage seems to be off and shuts down the compressor. Can I bypass the temp guage to leave th ecompressor...
You can but the unit will have not control over temperature, and you can cause the unit to freeze up or slug the compressor w/ liquid refrigerant causing premature compressor failure. I would recommend replacing the thermostat if it is not holding proper temperature, but if dead set on bypassing it use a volt/ohm meter after unplugging it to find the normally open contacts and wire those wires together taking into consideration that the fan must run constantly with the compressor.
Sep 23, 2011 | LG LWHD1500ER Wall/Window Air Conditioner
Termperature Control
Well, the control circuit get input from thermostat.
what you need to change is right the thermostat. I do not think there is any way to lower fridge temp if you do not replace thermostat.you could put an additional switch to turn on/off manually the compressor when you need extra cold, but in this way you risk to damage the motor.
You need to change the thermostat with one that switch on at a lower temperature. to do this you may need to use a non-fabric part.
regards
Mar 10, 2008 | Refrigerators
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
The beer froze in the chiller what could be the problem
The thermostat is stuck in the closed position if you noticed that the unit runs and runs and runs without cycling off sometimes. If it cycles, move the thermostat setting up in number (warmer). Make sure, if the unit is in your garage or otherwise not inside where it is warm, that the temp of the outside air isn't below freezing - coolers don't do warming and will not protect the beer from frigid atmospheric temps. Good luck.
Apr 20, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Vulcan freezer 300lt
Replace your temperature control
Nov 25, 2007 | Freezers
Used as beer fridge but contents freezing
The defrost timer in the unit is probably bad take a look at it there should be a timer with a slot in it around the thermostat that you can turn with a common screwdriver the timer should click and go into defrost mode and the unit should shut off, if the unit shuts off and it still doesn't defrost you either have a thermal cut-out that is bad in the freezer next to the heater element or the heater element itself is bad. Let us know :-)
Sep 14, 2007 | Jenn-Air JUC2450ARS Compact Refrigerator
Cooler is freezing my Beer!!
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Nov 20, 2006 | True 3 Keg Direct Draw Beer Dispenser,...
Krups BeerTender B95 Beverage Dispenser Logo
59 people viewed this question
Top Krups Refrigerators Experts
Tom Chichester
Terry Hair
JonSnell Electronic
JonSnell Electronic
Are you a Krups Refrigerator Expert? Answer questions, earn points and help others
