Question about Optics
I need manual for hardin 6-5 star hoc - Optics
3 Suggested Answers
Dave Duff
  • 30 Answers
SOURCE: Hardin Optical Deep Space Hunter model DSH-6
your telescope appears to be a newtonian reflector on a dobsonian mount. This type of scope is basically a point and shoot design, simplicity itself and many experienced astronomers swear by them, for there ease of use, set-up time etc.
The number 6 in the model number denotes the aperture (size of mirror) in inches. This is a good starter scope (much better than these small scopes that boast 525 X magnification) and with it tou will be able to clearly see Jupiters four main moons and the planets cloud belts. You will be able to see Saturn and it's ring system. Many nebulae, star clusters etc will become visable, that were invisible before.
Getting started with this kind of scope is pretty easy even for an absolute beginner. Set up the scope on a flat even surface, putting it all together should be self-explanatory. Insert the lowest power eyepiece (Usually the one with the biggest lens, and the one with the biggest number i.e. 40mm) and begin by pointing the open end of the scope at a bright object in the sky. To get you going with a bit of a buzz, I suggest Jupiter. Jupiter rises in the SE at 20.50, and is due South at around half past midnight, Look for a bright star that doesn’t twinkle to the right of the moon at about midnight, and that’s Jupiter!
Whilst looking through the eyepiece, carefully move the scope back and forth, up and down in the general direction of the planet. Remember, you are only looking at a very small part of the sky, probably about the size of a full moon.
It is unlikely your scope will be in focus at this stage so what you will find will probably look like a doughnut. When you find this “doughnut” you will need to focus. Adjust the focus knob until you see a crisp image of a small disk. If you are in Europe, you will see three bright moons (two on one side and one on the other) the fourth is hard to see tonight, but if you are lucky, you may glimpse a view of the shadow of this moon (Europa) as it crosses the disk. On the East coast of the US, you will also see three moons clearly, the fourth, Ganymede. Is still in Jupiter’s shadow at half past midnight, but by 1pm, it will become visible as it moves out of the shadow.
Keep looking for Ganymede during this half hour, it makes interesting viewing, and gives a sense of realism and motion to the whole event.
Try using different eyepieces as you become more accustomed to your scope, everything you see is upside down and back to front. Using different eyepieces will require re-focusing, but with a bit of practice, it will become second nature.
Finally, adjusting your finder scope. You will notice that the finder is held in place with two (sometimes three) adjustable screws. It may be best to set the finder scope up in the daytime. First find a distant object in the main scope (the further the better) a chimney pot on a distant roof etc. Then using the adjusting screws, centre the same object in the finder. It’s a bit fiddly at first, but you will get the hang of it. Then when night time comes, finding celestial objects is much easier. First locate the object in the finder scope, centre it, and the object should be in view in the main scope.
Hope this helps to get you going.
Kind Regards….Dave
Posted on Jul 17, 2008
SOURCE: Trying to overhaul/rebuild a Hardin
You will not find any instructions for this particular mount and tube.
However here is a video on Telescope mirror cleaning-- and a web site on disassembling an EQ5 mount which is similar to your moun.
http://www.youtube.com/watch?v=9Y8xFnXFVGQ
http://www.astronomyboy.com/cg5/
Posted on Jun 10, 2011
F5 Newtonian Dobsonian 10" I need
Hardin Optical is out of business-- however a well stocked hardware store should carry some springs that will work just fine.
Jul 04, 2011 | Hardin Optical Deep Space Hunter 10...
Trying to overhaul/rebuild a Hardin STAR HOC 8-4 7.9" f/4 Newtonian reflector with equitorial mount. Has been sitting out in the desert for who knows how long and is covered with fine desert...
Jun 10, 2011 | Hardin Optical STAR HOC 8 (160 x 200mm)...
I have a hardin deep space hunter 6 newtonian telescope with a dobsonian mount about 6 years old, the finderscope glass is broken, would like to repair it or replace it .Any ideas ? thanks Ray
You can buy a new finder scope. There are many retailers on-line--
Here is one:
http://www.telescope.com/Accessories/Telescope-Finder-Scopes/pc/3/49.uts
May 22, 2011 | Hardin Optical Deep Space Hunter 6 (240 x...
Also looking for a refractor 150mm apo of the brand Hardin of course
Hardin is now out of business. You never said exactly what your problem is?????
Oct 12, 2010 | Hardin Optical STAR HOC 90mm (200 x 90mm)...
Looking for a reducer/flattener, hope you can find one for me??
You can buy focal reducers from many on-line retailers here are two--
http://agenaastro.com/optical-accessories.html?SID=s3au8hupdmtagk3u0mebnvoqq6&cat=27
http://www.optcorp.com/category.aspx?uid=105-172
Oct 12, 2010 | Hardin Optical STAR HOC 80mm Telescope
I need a manual for the deep space hunter 6 inch purchased around 2002. model number DSH-6
Why would you need a manual for a simple Dobsonian reflector telescope.
The Company does not exist-- anymore.
A manual only showed how to assemble the telescope, it DOES NOT tell you how to USE the telescope to find objects in the sky.
This is a good beginner telescope by the way. Here is how to get started using it:
1. During the day time align the small finder scope and the big scope on the same distant target. Then you can use the finder scope to locate and POINT the main tube to objects in the night sky.
Also during the day put the eyepiece with the largest number written on it into the focuser. This is your LOWEST magnification. Practice focusing on a distant object. The image will be upside down--- this is perfectly normal. Nothing is wrong with the scope.
The moon should be the first target at night.
Buy two books: Turn Left at Orion and Nightwatch.
Download the free monthly star charts at:
http://skymaps.com/downloads.html
You can watch there videos to learn about Astronomy for beginners--
http://vimeo.com/channels/tas
Aug 26, 2010 | Hardin Optical Deep Space Hunter 6 (240 x...
Realignment directions for 10'' deep space hunter telescope
support@telescope.com has manuals that can be downloaded. The information is in the manual of a similar telescope.
Nov 23, 2008 | Hardin Optical Deep Space Hunter 10...
Hardin Optical deep space hunter 10" telescope
i have a deep space hunter telescope but have lost the manuel can i find one
May 29, 2008 | Hardin Optical Deep Space Hunter 10...
Optics Logo
100 people viewed this question
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
