Question about Curtis LCD2425A TV
Can't change source
When i trying to get source changed to hdmi
    New Friend:
Go to the source menu (source button).
Use up and down arrows to select the correct HDMI jack.
Use right arrow to make that selection.
Posted on Jul 21, 2015
Tv does not receive sound from new digital cable box through hdmi cable.
It's probably a settings issue on your t.v., you can change where you get sound from (audio source), and it might be set to something like an analog audio source. Just change the audio to come from your HDMI. Not sure what model your t.v. is, but try going to settings, sound, and find something that looks similar to audio source, and change your settings from there.
Jan 09, 2016 | Audio Players & Recorders
I have a toshiba 40rv525 tv and none of the hdmi ports detect any video from the cord. I have tried all the ports and multiple sources. Any ideas?
What is the source video you're outputting from to the tv's hdmi input? Check to be sure the device's output is set to the proper HDMI Out, also be certain that when you're plugging into, say, HDMI1 the TV input is also set to HDMI1. Let me know if you need more details on how to change the source on the tv.
Oct 27, 2014 | Televison & Video
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Can i hookup theis computer to my tv using a hdmi cable?
Yes, your notebook comes with an HDMI port. You will need an HDMI cable to connect to the TV (usually LCD TVs come with an HDMI port). After the connection has been made, change the source in the TV by clicking the "Source" button on the remote. It usually changes in the following sequence - AV1, AV2, HDMI.
Jun 25, 2011 | HP Compaq Presario CQ50-103NR Notebook PC
Iplugge in my PS3 using an HDMI cable and i get no feedback
ps3's are a pain in the _ss..
you need to connect it through your standard cables as well.. use the component cables that came with the ps3 and connect it to your tv's coloured inputs..
change the tv to that source and then go to the video settings on the ps3, and then choose the hdmi option..
now.. once the option is chosen, you have about 30 secs to change the source on your tv to the hdmi source to see the picture while the timer counts down (making sure both the hdmi and the component cables are connected to the tv at the same time)..
now that you are on your hdmi source on the tv, choose accept (X) on the ps3 menu and you should have your hdmi setup
if you run out of time, no problem, just go back to your component source input and repeat the process faster
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
I have a Phillips HDTV model #42PF7421D/37. When
Try another hdmi wire. Physically look at the hdmi port and see if there is damage done to the port. Change the source. IE another cable box, xbox 360 dvd play etc. If all else fails, change SSB or Scaler. Depending on the set. It'll be one or the other. I don't have my information with me at the moment to distinguish which one you'll have.
Dec 08, 2009 | Philips Televison & Video
Curtis LCD2425A TV Logo
83 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
