Question about Netflix
Haveing proplem with my internet need how to put a code in
    Top Expert:
  • Netflix Master
  • 14,161 Answers
Posted on Mar 15, 2016
I got a proplem with my account in yahoo and i really need it coz its all my work on it :(
I got a proplem with Problem with the Yahoo Messenger i got a proplem with my account in yahoo and i really need it coz its all my work on it :(
Jun 08, 2011 | Yahoo Messenger
Tip
Old school proplem solver
ok this can be applied to just about any vehical ever made ...but my experience is with ( for this case) my 1991 jeep cherokee..i had all kinds of proplems and codes...they consisted of hard starting, reving up and down, cutting out,(engine dying), worse and worse gas milage..stumbling..o2 sensor codes( fault o2 sensor)..bad isc motor..bad map sensor...bad temp/thermostat and my brakes kept getting worse..(softer and softer...so i started posting my proplem all over the net and even broke down and took it to a jeep service center...i spent well over seven hundred dollars and still most all of the proplems remained...so i referd back to an old and very simple way to search for proplems with any motor...(cheapest way first)...lol well i guess not first..at least not for me haha..i started unpluging the different sensors while the engine was running to see if there was any change and every one seemed to change things a little ...so i then took a can of carb cleaner and started spraying ever gasget surface and vacume hose...!!!!..i found that the engine changed pitch every time i sprayed the intake gasget...!!!..so i bought a new one for ten dollars ...spent 4 hours to replace it .. and it fixed every one of the proplems i had...it sounds crazy but if you put a little thought behind it ..it makes perfect sense...o2 was reading faulty and lean(more oxygendue to leak)..brakes were getting softer(due to drop in manifold vacume) map sensor was reading faulty and causeing stumble and cut out (also due to drop in manifold pressure) temp/thermosate reading due to idle air temp (which needs to coencide with temp sensor) not recieving proper air flow reading also due to leak...well as much as i can go on about this i am just posting this where i can i hopes that my adventure saves someone a little money....remember i spent over 7 hundred before figuring out this simple ten dollar fix!!!! and since the intake and exhust share a common gasget it is pron to leaks....good luck and i hope this helps
on Jan 14, 2010 | Jeep Cherokee Cars & Trucks
Hi im having proplems linking to the internet with my wireless router, its asking for a password but i havent put any password on it. Ive tried resetting it and still having no joy.
I am actually posting a link to give you steps to this, The SSID or Network name and the wireless key is what you will need. It is usually written on the router itself.
http://www.support.dlink.com/emulators/wbr2310/wireless.htm
The default settings you need to change is Admin and user, Hope this link will help you.
Thanks
Lani
Oct 12, 2010 | D-Link 802.11g Wireless Router WBR-1310...
HI Dears:How to get some thing from the internet.
Mohamed i`m Egyption like you try to discripe your proplem to me with arabic language ... it would be better and I will solve your proplem to you ISA or try to cntact me at
elmat7on2@gmail.com
any way go to
www.google.com
it`s arabic search engine and write what u r l;ooking for with arabic and you will get is ISA
May 02, 2009 | Microsoft Computers & Internet
I am not able to dowenload the a.reder. wt is the proplem??
Make sure if you have an old version or any file folder , it has to be deleted before you can install new.Make sure the speed of your internet is good.
Usually, it's a big file. You need to make sure you have the space and a good internet connection. A small disconnect in the connection would result in an error.
Any further help, let me know.
Thanks for using Fixya.
Apr 28, 2009 | Computers & Internet
Audio proplem
control panel volume control check to see settings are correct
are you plugging headest in to the right place on audio card
Jan 25, 2009 | Compaq Presario Notebook
Nokia N73 Lock Code
THE NORMAL WAY TO RESET THE SETTINGS IS GO TO SETTINGS THEN GO TO PHONE THEN GO TO RESTORE FACTORY SETTINGS AND IT WILL ASK YOU A CODE PUT 12345 AND PRESS OK IT WILL RESET YOUR SETTINGS PLEASE DO NOT FORGET TO BACKUP YOUR DATA NORMALLY IT DOES NOT GO AWAY BUT JUST TO BE ON SAFE SIDE.HOPE IT WORKS FOR YOU
Sep 17, 2007 | Nokia N73 Cellular Phone
Netflix Logo
Top Netflix Computers & Internet Experts
David Payne
David Payne
L Pfaff
L Pfaff
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
