Question about Dell Alienware Computers & Internet
Beeping continuous no bios, no boot
When plugged in , all fans and powr light come on.The Mother boar beeps continuously and there is no boot to bios or windows...
Pyrhyc
  • 2028 Answers
SOURCE: T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Posted on Aug 30, 2008
brighthm
  • 36 Answers
SOURCE: BIOS beep codes on packard bell home pc
You need to check your RAM, make sure it is seated properly.. this should fix the problem!
Posted on Oct 28, 2008
Eddie333
  • 176 Answers
SOURCE: Latitude D600 beeps twice
Sounds like you have a video card problem.
To run the Dell diagnostics perform the following steps:
  1. Shutdown the computer.
  2. Press and hold the <Fn> key (next to the <Ctrl> key), then press and release the power button.
    Release the <Fn> key when:
    • The keyboard lock symbol lights begin to flash AND/OR
    • In the upper left corner of the screen shows Diagnostic boot selected
  3. The diagnostics testing automatically begins.
    It may take a few minutes before any alert tones are heard.
  4. Watch the screen for images such as the Dell logo, progress bars,or lines of text and/or listen for beep tones that sound similar toMorse code.
  5. If the screen does show an image, write down the codes that appearon the screen. If the screen does not show an image, write down thebeep tones that you are hearing.
    • Before going further, please click the link to listen to an example of a beep code. Sample Beep Code
    • The beep codes will begin with a quick series of high pitched beep tones, then a pause, then 3 sets of beep codes.
      Write down the 3 sets of beep codes that you hear.
    • If an error code is recieved, scroll back to the top to "Choose an option"and choose "A beep code is heard or an error code is seen. The beep code is not 3-3-3 or 3-3-4."
    • If there is no error code, continue with step 7.
  6. After approximately 2 minutes the system produces a single alert tone and should display colored bars with the prompt Were color bars displayed? (y/n).
    The alert tone is repeated 6 times, once every five seconds for 30 seconds, then the second test automatically begins.
    Press the <N> key on the keyboard to skip the timeout and immediately start the second test.
Posted on Jan 04, 2009
  • 82 Answers
SOURCE: Bios continous beep, repeated ////, intermittent touchpad issue
The beeping when powering on is from the keyboard buffer being filled up by a stuck key. Same thing in windows. Best bet is to just replace it as it is pretty cheap.
Here is a link for one for $25
Easy to swap out also , here is a step by step
Posted on Mar 05, 2009
  • 2666 Answers
SOURCE: acer aspire 5315 beeps on startup
See here
http://www.computerhope.com/beep.htm
Posted on Mar 22, 2010
Continuous beep motherboard will not boot
check the battery for the mother board memory. flat battery can make it no startup. also if that is fine remover the hard drive lead and turn on if it comes on then the hard drive is causing the fault. do same with rom's.
Mar 24, 2014 | HP ECS ACER 946GZT-AM V1.0 SOCKET- LGA775...
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
My computer cannot boot because of long beep
beep code usually means a basic function was unable to start. A basic function might be reading memory, displaying video, or being able to send information to a hard drive. The most common problems that cause beep codes are memory and heat-related failures caused by a build-up of dust in critical cooling areas. Use the beep code tables in this document to help find what hardware component is causing the problem. This might reduce the time required to find the hardware component that needs adjusted, reseated, or replaced. WARNING: HP recommends that these steps be performed only by someone with experience in working on computer hardware. Incorrectly handling sensitive internal components can further damage the computer and can introduce the risk of personal injury. Using the correct environment for working on computers (ESD precautions and tools), use the following steps to isolate and fix the problem:
  1. Turn on the computer.
  2. Listen to the beep code and write it down. Write down the number of beeps before each pause, if the beeps are long, short, high in tone, or low in tone. You can use the other sections in this document to look up the beep code description. The beep code and its description can be used for further Internet research if needed.
  3. Note which fans are spinning, not spinning, or making strange noises. It might be possible to prevent the beep code by setting the fan speed to a higher setting in the BIOS setup utility or by cleaning the cooling fins and vents.
  5. Check the case fan and power cable.
    1. Turn off the computer by holding the power button for five seconds.
    2. Disconnect the power cord and then disconnect all external cords from the computer.
    3. Remove the side panel to open the computer.
    4. If the case fan was not spinning, make sure the case fan power cable is connected to the correct pins on the motherboard. Replace the fan if it was making excessive noise or was not spinning. If you had to plug in or replace the fan, replace the side panel, plug in the power cord and turn on the computer. If the beeps continue, continue to the next step.
  6. Disconnect the power cord and remove the side panel and perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
    1. Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
    2. Remove a memory module. If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module. Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
    3. If the computer has a graphics adapter, remove it. If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step. If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
    4. Remove a PCI card. If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card. Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
    5. Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
    6. At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly. Otherwise, have the computer serviced by HP or by a qualified service center.
Jul 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
