Question about Acer TravelMate 2300 Notebook
Permanent settings in control panel
My laptop features "enable tapping," so that one may tap the mouse pad thus simulating a left click.  From control panel I select mouse and go to devise settings and from there I disable tapping.  Yet, when I restart the computer the tapping feature is once again enabled.  How do I make my desired disable tapping setting permanent?
  • 117 Answers
Function and f7 key disable and enabled mousepad
Posted on Oct 24, 2007
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
My touchpad is working only as a mouse, the tapping is not working..why is that ? I have an aspire 3680 mouse work and the 2 click buttons too only tapping is not working. I have check all drivers and they...
1. Go to control panel
2. open mouse options
3. click the device settings tab and you should see your touch pad as one of the devices.
4. Make sure your touch pad is highlighted and click the settings button
5. one of the options is tapping, and you can enable it here
That should get your mouse to click on touch pad taps.
Good Luck!
John Vickers
Aug 13, 2011 | Acer Aspire 3680-2682 Notebook
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
Can I disable the touchpad double click feature on
You can go to the control panel and click on Mouse. Look at the top tab and click on settings. The window that comes up shoes the touchpad device, highlight it and click on the settings button. Look at the list of options and click on tapping. Look for the little box and uncheck if it says enable tapping. This will disable the tapping function of the pad, so you will only be able to scroll with the pad and click with the buttons. Click apply and ok.
Jan 29, 2010 | HP Compaq Presario 2200 Notebook
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
Mar 31, 2009 | Acer Aspire One PC Notebook
Jumping cursor
This is a really common problem thats not actually a problem.
Go to trackpad settings and make sure tap to click is off.
Most laptops allow you to tap the track pad to act as a mouse button, try it go to an icon tap the trackpad youll see that the icon highlights as if you are actually left clicking.
When your typing the trackpad senses your arm or wrist occasionaly and thinks your tapping the mouse, thus moving the cursor.
So go into trackpad settings and turn off tap to click.
Jan 19, 2009 | Acer Aspire 1690 Notebook
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Touch pad not working
Oh, you mean it doesn't click on tapping.
Okay, this will surely fix it. Something has disabled the tap feature and you need to enable it again. I have seen it with a couple of computers and I fixed them.
Go to Control Panel. Enter the Mouse Settings and select the last (Devices) Tab at the top of the dialog box that appears. There, click the button Properties. In the Window that comes up, select the Tapping option in the left pane. There, click the Checkbox 'Enable Tapping' or similar.
Now click Apply as many times it requires to close off all the Windows that have come up. Now try moving the mouse.
Please rate this answer. It is really gonna 'FixYa'!
Dec 03, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
