Question about Hoover HTC243 Top Load Washer
Hoover 500mb wont spin sometimes doesent agitate properly
2 Suggested Answers
  • 610 Answers
SOURCE: Hoover 500Mb Heavy Duty washing machine,it is extremely loud on spin cycle, works fine but very very loud on spin cycle? Does anyone know what is causing it? Thanks
The main seal has allowed water into the spin bearings...
Posted on May 25, 2016
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
My Hoover 500Mb is extremely loud on spin cycles, it works great but very loud just on spin?
as you have probably found out by now the drum bearings are worn out probable due to the seals leaking ,new set of bearings and seals if not already fitted.
May 25, 2016 | Hoover Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
700LC will not spin
The older Hoover had a problem with the clutch drive seizing. Sometimes it was caused by the aluminium housing on the gearbox breaking or cracking. When this happens, the clutch pawl doesn't release the clutch gear properly. The clutch stays in the locked position and then it wont allow the tub to spin. Its not often the top bearing fails. A common sign of gearbox / clutch failure is a brown oily stain spread all over the inside of the cabinet in line with the bottom of the gearbox. This means that the gearbox has slowly filled with water through a failed gearbox seal and when it gets to this stage, its not an economical repair. Time for a new washer unfortunately.
Feb 22, 2014 | Hoover Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
My machine seams to go slow with a light load 500mb h/duty
500mb from memory was a Hoover top loader ??? It could be just the belt slipping underneath, but also have a look inside the drain pump hoses for blockages. These were notorious for blocking with coins and other foreign objects. . If the machine couldnt pump out properly, when it went onto spin, it would only go very slow as the machine wasnt able to build up any speed with a full load of clothes and water.
Jul 26, 2011 | Washing Machines
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Hoover HTC243 Top Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
