Question about Building Materials
Wayne dalton garage won't open when I click button
SOURCE: Garage Door issue
http://www.wayne-dalton.com/Files/ProductManuals/Residential_Garage_Door_Openers/DoorMaster/300640%20P4%207-9-2007.pdf
Posted on May 26, 2008
  • 4 Answers
SOURCE: wayne dalton garage door is humming but wont open
Likely the plastic gears are worn out. Unplug the unit from power source, remove the cover, look at the gears. If worn, it will be obvious from the shavings from the gears. You can buy the gear kit on EBAY for a little as $20 depending on the manufacturer and model. Before removing the chain drive, lock a pair of vice grips on the chain and metal chain rail to keep the chain from turning from its current position. The gears can be replaced without removing the opener. Even if you have to remove the opener, it is a simple task. Most have four bolts that need to be removed and it will be in you hands.
Posted on Jan 15, 2009
SOURCE: My Wayne Dalton garage door will open with remote but not close
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Posted on Jan 16, 2009
SOURCE: I have a wayne dalton garage door opener and the light stop worki
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
Posted on May 10, 2009
SOURCE: Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Posted on Jul 28, 2009
How do I reprogram a Wayne Dalton wireless keypad model 02-3039UH?
Usually by reading the instruction manual and doing what it says to do .at least it worked for my neighbor a few days ago .
Sep 07, 2015 | Wayne-Dalton Wayne Dalton 297138 or...
How do i reporgram a wayne dalton keypad
I would look into buying a liftmaster jack shaft its a much better unit but to get u buy just press the little red button on the opener type in your code
Feb 04, 2015 | Wayne Dalton Remotes Wayne Dalton 327308...
Need instruction manual for Wayne Dalton Chamberlin WD 220 grage door opener
The LiftMaster or Chamberlain web site has instruction manual downloads for all the models.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Don't have instructions for my wayne dalton door need spring instructions
Wayne- Dalton uses 4 different types of counter balance springs-extension, torsion, torquemaster 1, and torquemaster 2. I would need this information for a good answer. A photo would help a lot too. Thanks BB
May 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Can i use the ''clicker'' model CLT1 with wayne dalton quantam 3316
It is compatible with Wayne Dalton opener manufactured between 1983 and 1987.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
21 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
