Question about DeLonghi Dolce Gusto Esperta - Titanium
Water leakage from base of machine - DeLonghi Dolce Gusto Esperta - Titanium
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
Is it possible for the homeowner to fix a Samsung dishwasher that has the "heavy" light blinking and will not run? The manual says it is a leakage problem but no leakage is detected.
You are correct, the HEAVY light blinking indicates a leakage problem. Remember that the Samsung DW's (dishwashers) have a base that holds the water so it doesn't run out on your floor. You will have to pull your DW out so you can remove the right-side metal panel. Pull the insulation up so you can look inside. You will see the floor of the plastic base has a low spot in it, and the water sensor is located over that area. That area must be completely dry (1/8" of water will trigger the error). Once you sop up and dry all the water there, you can start up the dishwasher and watch for leaks. The most common places are the drain pump (also visible on the right-hand side) or the drain hose. And sometimes, there is no leak, but water got in there because you used too much detergent (or the wrong detergent), and it caused it to overflow into the base.
Feb 15, 2015 | Samsung Dishwashers
Blinking heavy light on Samsung DW7933LRAWW. please help!!
That indicates a leakage error. Water has leaked down into the base of the machine. You will need to sop up and dry out all the water down in there, then find the leak, which is most commonly caused by a bad drain pump and/or drain hose. Good luck!
Sep 10, 2014 | Samsung DW7933LRAWW White 24" Front...
F 2 is flashing
Check the drain pump filter for foreign objects. Video.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
Service manual
Each model Duet has its own set of errors and solutions in a jacket behind the service panel. Th service manual will help in disasembly. Use your tech sheet to do the diagnostics and party on.
Jul 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
There is water leakage on my La Pavoni Europiccola machine
I am a domestic coffee machine engineer based in Glasgow, Scotland and i service, repair and refurbish these machines on a daily basis. You will probably find that the gaskets which are holding the sightglass in place are completely solid and resemble a hard plastic like gasket. There will definately be gaskets there as if not the sightglass would rattle about and the water would pour straight out. It depends on which sight glass nuts you have but if they are the clear plastic nuts you will find either black, white or clear gaskets underneath and if the nuts are metal then you should see brass washers first and then the gaskets underneath the washers. These are easily replaced and can be purchased from our website www.theespressoshop.co.uk I hope this helps and if you have any further questions or queries then please do not hesitate to get in touch at domesticespresso@live.com
Apr 05, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Model A511 washer Agitator is not moving as vigorously as it used to. Removed front and found excessive oil residue in the bottom. Repair or buy ?
excessive oil . is usualy found under the machine / if inside / on side's of shell this could be water seal leakage . the 511 is a very good machine but its also very old . . agit problem is usualy in the belts and motor roller base . /try cleaning the pulleys and replace belt set / 2011124 and 2011125 / put a roller base set w springs . this will perk it up ,,use info on belt package for belt adjustment. they run loose. ( do not over tighten .)
Dec 18, 2009 | Washing Machines
Machine is leaking water
This could be anything from the tank base to the outgoing hose from the thermoblock. I recommend to visit a local servicecenter. If you`re handy; open the machine and locate the leakage; maybe it`s just an o-ring that needs replacement.
Jul 29, 2009 | Jura Capresso Impressa F9 Espresso Machine
Dishwasher beeping when you put it on rince or wash. checked water is on rince aid is full & salt is full
check to see if there is any sign of water leakage from the machine {usually from the rear} if the base is sealed it could be that the machine has gone into safe mode due to the machine thinking its got a water leak{some make and model dish washers ahve anti flood switches fitted to the base of the machine.
Jul 23, 2009 | Dishwashers
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
Feb 23, 2009 | Haier HWD1000
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
Jul 10, 2008 | Samsung AW0505M Air Conditioner
DeLonghi Dolce Gusto Esperta - Titanium Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
