Question about Panasonic Camera Lenses, Flashes and Accessories H-FS014042 Lumix -
Panasonic H-FS014042 not working with GF1
Hey All, Have just bought the H-FS014042 lense for my Panasonic Lumix GF1. THe power zoom and focus is not working. When I turn the camera on it zooms all the way in and stays there. I have the latest firmware on both the camera and lense. Not sure what else it could be. Any help would be great.
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
If you placed the lens correct, till it clicked while turning, it should work correct. Did you check if there was anything on the contacts, before placing the lens?
Can you focus manually? and is your camera in the auto focus mode?
I can't make more at this moment. Success.
Posted on Jan 02, 2014
  • 16 Answers
SOURCE: panasonic lumix dmc fz18 won't zoom in or out
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
Posted on Sep 05, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix dropped
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
Testimonial: "Thanks so much on the advice on the dropped Panasonic Lumix camera! I went straight to number 7 and twisted the zoom, worked wonders!! thanks a lot!:)"
  • 11967 Answers
SOURCE: Hi I have a Panansonic Lumix - DMC-FS25.
Posted on Apr 19, 2010
Testimonial: "You saved my camera! I reckon it was sand particles in the lens mechanism, 3 and a little bit of 7 sorted it out. Many, many thanks!!!"
lock123
  • 6831 Answers
SOURCE: My panasonic lumix DMC-ZS1 has "Zoom Error". How
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
lock123
  • 6831 Answers
SOURCE: System error: zoom message with Panasonic Lumix FS15 camera
Hello
Regards
Andrea
Posted on Oct 12, 2010
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
Panasonic LUMIX 14-42mm GX VARIO PZ lens on GF-1 Body
When using different lenses, a few things should be kept in mind.For some you need an adapter and not every lens ail work as the lenses made for this camera. Sometimes focus or other things needs to be set manually. So even when you can connect a lens to the camera you don't have any guaranty it will work fully automatic and correct. Please read the manual tag came with your camera, about the differences between the four thirds cameras and lenses.
Dec 03, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
Panasonic LUMIX 14-42mm lens to a gf1 body gets stuck on zoom how to fix
What do you mean by "gets stuck on zoom? Are you getting any type of error message?
Dec 03, 2013 | Panasonic Lumix DMC-LZ2 Digital Camera
Dmc gf1 flash won't work
The camera requires service, this is a nag screen and will not reset itself without being serviced.
Jan 17, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
I bought a Lumix DMC-GF1 in Japan. BUt it only supports japanese. is there a way to transfer it into English?
Hi! Im afraid that theres no possible way to do that for its a japanese domestic market. Im sorry but I hope this shed some light.
Oct 07, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Can I use Lumix Panasonic DMC-GF1 as a web-cam
No. The DMC-GF1 was designed as a camera, storing to a memory card. It was not designed to stream videos to another device.
May 06, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Describe your Panasonic Lumix DMC-FZ18 Digital
the zoom in the camera is manual, are the lenses moving inside, when you go from 35 to 420 mm?
Have you dropped your camera or has is experienced a shock of some kind? In that case you would need to send it for repairing the lenses, do not attempt to do that on your own.
Oct 18, 2009 | Panasonic Lumix DMC-FZ18 Digital Camera
HELPPP!! My camera will not focus when zooming at all.
is it possible that the focus switch on the left side of the lenses is set to macro, or manual focus? That could make your camera "go blind".
Vladimir Z
May 20, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Viewfinder focus
Mickykay,
Have you tried focusing the diopter? The focus wheel is just left of the viewer. If you know all this then consider one more thing. There is a plus and minus setting for your eye so roll the wheel slowly to not miss the sweet spot for your vision. goodeye
Jan 13, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Camera Lenses, Flashes and Accessories H-FS014042 Lumix - Logo
50 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
