Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How do i connect DCM425 modem to cisco linksys E800 router
I can't connect my router to the modem and need assistance doing so
dbarchitect
  • 150 Answers
SOURCE: RCA DCM425 modem ethernet connection won't work
In short, you have to either
  1. renew your ip on Computer 1, or
  2. hard-reboot your cable modem and then reboot or renew your ip on Computer 1.
Details below.
The modem is communicating with the servers at your ISP (Internet Service Provider) to give your computers an IP address. The ISP may have your modem set up to be issued only one IP address. Thus using both USB and Ethernet could be restricted by your ISP.
The IP address is most likely a dynamic IP that expires after a few days or weeks, unless you bought a business account that has a static IP (which is used for hosting permanent websites).
When a computer is not communicating with a Cable Modem or you shift between the connections on the modem, it may be necessary to re-establish configurations. The following can be steps to reset all components to re-establish configurations:
  1. Do a hard-reset on the modem. On the back of the modem is a reset pinhole. If you press the button quickly, this can soft-reset the modem, just restarting the modem. If you press the button and hold it for more than 10 seconds, this can hard-reset the modem, thus resetting and re-establishing configuration with the ISP servers.
  2. Restart the computer or at the command prompt (Start | Run | Cmd | Enter) issue two commands ... "ipconfig /release" and then "ipconfig /renew". This will release your IP and request a new one from your ISP.
These steps are required when adjustments occur especially when shifting between connections on the back of the modem.
Posted on Nov 26, 2007
Arius
  • 446 Answers
SOURCE: how to flash my dcm425 cable modem
Message Flashing - flashes to indicate unread email (only if ISP enables this feature)
Off - no email messages pending Cable Activity Flashing - indicates data traffic; modem is in use
Off - indicates no current data traffic Cable Link On - cable modem is connected to the network
Flashing - cable modem is attempting to connect to the network
Off - cable modem not connected to the network PC Link On - PC is detected but no current activity
Flashing - activity between PC and modem
Off - no computer detected or modem is in standby Internet On - If this and the Cable Link light are steady then the modem is connected
Flashing - modem is searching for a downstream signal
Off - power is not supplied to the modem or modem is
only ISP provider can help you on this one
Posted on Sep 04, 2008
rcirone203
  • 70 Answers
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Posted on Jul 16, 2009
Geekman
  • 32281 Answers
SOURCE: how to secure my wireless connection for a DCM425
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Posted on Oct 05, 2009
  • 27 Answers
SOURCE: I have a RCA DCM425 MODEM and i need wifi. So What
If you have an Ethernet port on your modem, you may use any kind of router. Else, only Wifi router.
Posted on Oct 30, 2009
Verizon dsl and cisco valet
Connect your computer directly to the Internet modem and make sure that you have Internet access directly from the modem.
If that is working properly then connect the modem to the Internet port on the router. Connect the computer to port 1 on the router.
Reset the router and configure it manually.
Here is link which will help you troubleshoot Cisco Valet M10 or M20 router
Mar 01, 2014 | Linksys by Cisco Cisco Valet Plus Wireless...
Problem cisco EA6500 to i-cable router HK
Power off Cable Modem, PC, router, and then disconnected them. Directly connected Cable Modem with PC (Don't connect the router) and power on Cable Modem. When Cable Modem is ready with LED lamps under normal status, also power on PC and try to access Internet service. If Internet service is resumed, please study the router setting of Cable Modem which referred to router's user manual.
Apr 21, 2013 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
Routor not connecting to modum
That is connect.
You will need to connect the router to the modem with the Ethernet cable.
First connect the computer to the modem with the Ethernet cable. Make sure that you can access Internet without router.
Connect the computer to the Ethernet port 1 and modem to the Internet port on Linksys router.
Open the setup page of the router.
Change the Internet connection settings according to the Internet service provider.
Create a wireless network and then connect your computer and other devices to the wireless network.
Read more about How to setup Linksys router.
Jun 21, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I have a dcm425 and when online gamming the router restarts itself every 10 minutes...
That's obviously a problem with your unnamed router, and not the dcm425.
Try looking for and flash upgrading (or downgrading) your router.
I had a Linksys router that I always kept up to date with the latest firmware, and one day it started doing the exact same thing we're talking about here. I had to downgrade the router to a previous version to fix the issue. Newer isn't always better!
Feb 26, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need to connect my play station 3 to the internet wirelessly
Your RCA DCM425 modem is just that, a modem. you need to buy and plug a wireless router into it. That will broadcast your internet connection for your playstation to find.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can't connect cisco router
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 23, 2010 | Linksys Wireless-G WRT54GS Router...
My wireless-g Broadband Router by Cisco and Linksys is not connecting no matter what I have done. Any help?
People who looked at the Linksys by Cisco WIRELESS G BROADBAND ROUTER WITH SPEEDBOOSTER ... It doesn't matter though, because the router is strong enough that I don't need ... I have no idea exactly why the accompanying software failed but the ... Linksys is not one of them.If a company will NOT assume the costs of ...
www.pcworld.com › ReviewsNetworking & Wireless
Jun 30, 2010 | Linksys Wireless-G Broadband Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
41 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
george  peters
george peters
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
