Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Clutch spring show photo of spring connected
Poulan Pro PB195H42LT Product # 960420107-00 Purchased April 2010a Looking for a photo for the drive assembly for this lawn tractor. The break down in the part's manual doesn't show the spring...
Try using a vice grip to attach spring. Look for wear marks where paint is missing from frame to help locate spring position. Hope this helps.
May 21, 2014 | Garden
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
Clutch just quit engaging, found small spring in the case/cover, need an exploded view of clutch assembly and a photo of new clutch plates.
For an exploded view of your clutch, go to www.bikebandit.com . The only spring that I can think of in the area is a small srping in the release mechanism but I can't figure how it got inside the case. As for your clutch plates, as long as they've got the oil grooves in them, they're fine. Although they don't look like much, they'll work.
Good Luck
Steve
Dec 25, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Removal and installation of 1988 harley sportster clutch
In order to remove the clutch from your bike, you must have a special tool. You'll need H-D #34761 in order to remove the snap ring holding the clutch together.
Disconnect the battery, drain the primary, and remove the primary cover. Once you have the primary cover off, you can remove the nut from the compensator sprocket at the engine end of the primary chain.
Install the H-D 34761 or equivalent tool and compress the clutch spring. Remove the snap ring and then back off on the tool to release the pressure on the clutch spring. Once the pressure has been removed, remove the adjusting screw assembly, the outer clutch spring seats, the clutch spring, the inner clutch spring seat, and the pressure plate.
Then you can disassemble the rest of the clutch. Remove the remove the four friction plates and three drive plates. Then you can remove the spring plate and the remaining plates after that. Remove the snap ring that holds the clutch assembly onto the transmission clutch gear and remove the inner and outer clutch shells, the primary chain, and the engine sprocket as a group.
For this job, I would recommend that you purchase a service manual. It's has pictures that show you what you're dealing with and in this case, a picture is truly worth a thousand words.
Good Luck
Steve
Nov 05, 2010 | Harley Davidson XL Sportster 883...
I have a 2001 kawasaki zr7s. My clutch is acting up. when i pull the lever in i have no clutch. i opened the case to get to the clutch, that rod thats in the middle of the clutch acts like there should be...
the "cluch push rod" should be pushed back by the cluch springs, if there was a bearing on the end it would have broken up and be laying inside the cluch case in bits! if you have taken the cluch to bits there is a thrust washer behind the cluch body and gear box shaft if you left this washer out you wont have a cluch? best bet is get a hayns service book for your bike maybe off e-bay and you will have all the info you need to fix it plus all the photos as well of all the parts
Jan 14, 2010 | 2001 kawasaki ZR-7 S
How to install a clutch?
the mechanic should place or connect the clutch pedal spring to the clutch pedal .connect the push rod to the clutch pedal.then connect the push rod to the clutch master cylinder then refill the clutch master cylinder .by means of pressure tube connect the clutch slave cylinder .then connect the clutch slave cylinder to the push rod .And the push rod connect it to the clutch pork. the clutch pork connect to the spring. then connect the fly wheel , the clutch linning ,the clutch disk ,the release bearing,then the clutch pork to the transmission shaft . then connect the transmission assembly.And you can goon with your date.
Aug 03, 2009 | Volkswagen Jetta Cars & Trucks
Spring Ext Elect Clutch became disconnected
look for a slot in an arm on deck this should have a pulley on it.
May 03, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
