Question about QuickStart CATIA V5 Full Version
In CATIA V5R16 File Send To Directory,showing Not Found Files.
In catia v5r16 we have created one assembly and then we have renamed all the files from windows location; where we have saved all the files,there we have right click on file and renamed all the files. Now from Desk Command we have found all the files and save d through save managment.In this assembly some contexctual and refference links has given through published elements(axis,sketch,planes) or parameters.Now we are facing Problem while send to directory,in this it has ha sshowing some number of files Not Found,which are same file name as before renamed.Please find the solution and help us in this regards
3 Suggested Answers
  • 20 Answers
SOURCE: When i use catia r19
Because its using alot of your processing power to generate the graphics. Also, you may just have a **** computer
Posted on Jan 20, 2011
  • 14 Answers
Use following cofiguration.
Intel Core i7 CPU Q 720 @ 1.6
Ghz w/ 3 Gb of Ram & Nvidia
Quadr FX 880M video/ 500
gb Hard Drive. This is about
the minimum you will need to run Catia V5 with any
manueverability.
Posted on Jul 15, 2013
Catia v5R16 shows "no warm
Mr. raulii,
As catia is the software for drawing, & big in size,....
so i want to suggest you to uninstall the same & install again in safe mode...
By the way you can start safe mode by pressing F8 button at start up....
Thanks,
Dhiren Motivaras
08530903006
Sep 16, 2011 | Computers & Internet
I am trying to install master of orion II on a windows 7 64 bit operating system and it won't open, because DPLAY.dll cannot be found. I have downloaded the driver, put it in the sys32 folder, the...
First install MOO2 on a computer were it runs and copy the entire micropose directory to the program files (x86) directory.
Then copy the dplayx.dll file from the windows\sysWOW64 directory and renamed it dplay.dll and put it back in the sysWOW64 directory (be sure the dplayx.dll file is still there) or if you have the 32 bit version it should be found in the system32 directory (I am guessing, but you will need a dplay.dll)
Found this great post about getting MOO2 to run in Windows 7, and even with the compatibility enabled it still has a graphics palette problem. The reason is because of Windows explorer, and to fix the problem you need to disable explorer.
I know this can be a little too much for some, there is an easier way.
Simply create a notepad file on your desktop, and paste the following.
(If you have 32-bit version of Windows 7.)
TASKKILL /F /IM "explorer.exe"
cd C:\"Program Files"\Microprose\Orion2
start /w C:\"Program Files"\Microprose\Orion2\Orion95.exe
start C:\Windows\explorer.exe
(Copy and paste below if you have 64-bit)
cd C:\"Program Files (x86)"\Microprose\Orion2
start /w C:\"Program Files (x86)"\Microprose\Orion2\Orion95.exe
Make sure you rename the text file to Moo2.bat, then it will launch Moo2 and disable explorer. Moo2 plays perfectly fine this way, even without any of the compatibility enabled.
The Batch file will also restore your explorer when you exit the game.
Alternatively, you could use DosBox to play the game.
Click Here for instructions
Hope this helps,
G33k
May 11, 2011 | Spectrum Holobyte Masters Of Orion 2 -...
Dear all, I have the Windows 7, will it accesible for CATIA V5 R19?. Please revert me. Regards, Chinta
Catia r19 is made for XP and Vista, and there should be no problem with it on Win7. Just make sure you have the necessary drivers for your CAD-enabled graphics card and any other input device you want to use with Catia.
If this post was helpful please vote for it with a Thumb Up. Thank you.
Jan 19, 2011 | Computers & Internet
When i use catia r19 the computer hangs after a while...why?
Jan 11, 2011 | QuickStart CATIA V5 Full Version
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
Installation of cracked version of catia v5r16 software
the version have been corrupted while cracking.so
use fresh products
Apr 13, 2008 | Computers & Internet
Bundled Pictures MoroKRZR K1m
Hi, I know this must be annoying to have all those crappy default pictures on your phone ad you want them off as soon as possible. Well you're luck I have a solution for you. Somethings you'll need to do the following: USB Cable P2kman or;(www.motomodders.net) MPT Depending on which method you want to use you'll use either software. But backup all the files that you are deleting off you're just in case. Even if you never plan to up load to your phone again. METHOD 1 This is just a case of deleting the actual wallpaper/screensaver/video using p2kman. METHOD 2 - the '0 Byte' Method This method uses MPT instead of p2kman. 1) On your PC, create a '0 Byte' file with exactly the same name and extension. Note that it is case sensitive. 2) Click on the Multimedia Studio on the right hand side of MPT. After it has loaded up, the left hand side shows you a Windows Explorer, while the right hand side shows you the Audio, Pictures, Video folders that correspond to those on your phone. This is the root directory. 3) Send that 0 byte file to your root directory on your phone. If this wasn't helpful, I'm sorry this is all I can suggest.
Aug 04, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
QuickStart CATIA V5 Full Version  Logo
320 people viewed this question
Top QuickStart Computers & Internet Experts
David Payne
David Payne
Are you a QuickStart Computer and Internet Expert? Answer questions, earn points and help others
