How to reprogram remote
I purchased the above with only one key. I need a spare - went to the 4X4 wreckers and got another key from another triton. Can I have THAT key programmed to my original key
3dmaster
  • 183 Answers
SOURCE: programming remote to open doors
Dear Customer,
If you didn't change your remote kit than its a best way to take to your dealer ,there is minor problem with sequence so they wil do free of cost with car document.
THNX
Posted on May 15, 2008
micromaster
  • 3614 Answers
SOURCE: Program Codes
may i know what brand and model of your TV and your remote control. kindly specify one of this..
thanks
Posted on Oct 29, 2008
SOURCE: Reprogram keyless entry
It took me a few attempts to program a new keyless remote for my 2002 Chevy Blazer.
Insert key into ignition but don' turn it yet. While holding down the UNLOCK switch on the door, the trick is to cycle the ignition ON OFF ON OFF as quickly as possible then release the UNLOCK switch. If done correctly the door locks will cycle 1x to acknowledge. Then hold both the unlock and lock buttons down on the remote for about 15 seconds. The locks should cycle again to confirm...Hope this helps.
Posted on Mar 27, 2009
  • 5 Answers
SOURCE: keyless entry suddenly stopped working
Make sure the button in the ignition switch indent is popping back up. Your lights and radio are probably staying on too.
Posted on Apr 08, 2009
  • 4 Answers
SOURCE: lost jeep 2000 grand cherokee key and remote
go to the car dealer and tell them that you need to get a new key and remote for your car
Posted on Apr 09, 2009
Location of fuel relay switch on 2004 ford f150 4x4 5.4 triton
Having fuel delivery problems ? It's not the fuel pump relay ! You probably have a bad fuel pump driver module . Pull you spare tire down an look on the frame above ! Watch this
F150 Expedition No Start P1233 Fuel Pump Driver Module
Apr 17, 2017 | Ford Cars & Trucks
I changed the batteries in the Keyless Entry remote for my 2002 Dodge Neon and it doesn't work. They only gave us one key set at the dealership when we purchased the car so it's the only button I have. How...
do you have a owners manual. you need to take out the service fuse on the car for 10 minutes then install it and push the lock button on the remote look for the owners manuel you can alway get one at the auto wreckers and while your their buy 2 remotes that belong the same car
Feb 23, 2015 | Dodge Cars & Trucks
Fob key problems
You need to have the spare reprogrammed as it has an immobiliser chip that sends a signal to the cars ecu so if the ecu doesn't recognise the chip the engine won't start.
presume
Dec 27, 2013 | 2004 Citroen Xsara 2.0
1998 chrysler LHS, I lost my original set of keys along with the remote unlock, I have a spare made by walmart and it only unlocks the door and starts the car if it a certain way, I had the car locked and...
you need to get a key made by the dealship and reprogrammed. i had a 999 chrysler lhs in my shop ,and I lost the key,and I had to send to the dealership
Nov 09, 2012 | Chrysler LHS Cars & Trucks
Avital 4100 remote start in 2000 pathfinder. worked fine. went to dealer for recall of fuel filler tube. while there had new key cut and programmed. the next morning the battery was dead. after jumping the...
if your key has a blue square where the metal meets the plastic on the key, you will need to reprogram the data module used to bypass the theft system, or remove the spare key that is installed and have the dealer reprogram it
Aug 09, 2010 | Nissan Vehicle Parts & Accessories
I lost my regular set of keys with the remote on the keyring but i have a spare key but when i unlocked my door with my spare the alarm went off and the car won't start because the fuel is disabled. It is...
need to go see the dealer and you must do this with the car on some models and they can reprogram the keyswab I would try to call them first and see if they might only need you vin# to do it.
May 27, 2010 | 1997 Saturn SL
My doors wont unlock or lock with the remote keyless entry on both keys. one set of keys being the spare and never used it cant be the battery in the remote?
could be, try installing a new battery on the spare remote and retry,if it still doesnt work, then reprograming will be needed, try the battery first and let me know what happens.
Feb 26, 2010 | 2006 Suzuki Swift
The battary in my spare key for my 2004 jaguar x type went dead while it was in a drawer. I replaced the battary in the key and the remote doesn't work. The remote in the primary key works fine. How do I...
Have both keys to hand. Rapidily flick the ignition to position 1 four times until you hear a chime then press the unlock key on both remotes. A chime should be heard each both times when you press the buttons
Jan 25, 2010 | 2004 Jaguar X-Type
Remote start will not work after dealer programmed a new key.
Yes you need to reprogram your immobilizer bypasskit and depend the model you have it is the program mode, I sugest you go under the dash and try to find out the bypasskit box wich is a small black box like 2"x3"in. and see what model you have.
Jan 23, 2010 | Directed Dei Valet 561r Remote...
Keyless entry suddenly stopped working
Apr 02, 2009 | 2004 Saab 9-3
Televison & Video Logo
378 people viewed this question
Top Televison & Video Experts
