Question about Westinghouse Televison & Video
Tv channel scan
Cant get to channel 60
3 Suggested Answers
  • 222 Answers
SOURCE: Channel scan doesn't complete
if you're only using antenna, maybe your signal is weak try using a better antenna, and aerial one.
Posted on Jun 15, 2010
  • 126 Answers
SOURCE: Cannot get channel 60 on tv. I have dish satellite
The TV is set to antenna not cable mode
go into the menu
then setup
then channels
change from AIR to Cable
then Autoscan it will get 60
Enjoy
Posted on Dec 03, 2010
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How to tune in Channel 60 in a Sony Triniton CRT?
assuming that you can "pick up" channel 60..and that the signal is strong enuff...that is part one..make sure you have a good antenna connection and that the antenna is positioned for maximum pick up, then do the scan mode on the tv via the remote control. it will re scan the channels and if the signal from channel 60 is being picked up strong enough, it will program the channel into your set automatically.
Sep 03, 2014 | Televison & Video
Help setting up my new tv
Click here to download the user manual to your TV. It has all details.
Oct 21, 2012 | Sharp LC-60LE600U 60" LCD LED TV 1080P
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I cant get my Sony tv to change to channel 60 or 73 so i can watch Dish Network tv. Help Please!
It is probably a problem with your original setup if it has a built in digital TV tuner then you may have accidentally done a scan for channels. If you did not have an antenna attached to your TV then it would have come up with no results but would only let you go to one channel (whichever one you started on).
Dec 26, 2009 | DISH Network IR Remote Control
I accidently changed the channel that I receive satalite tv on, dishnetwork can't solve the problem. TV will not take more than one number & dish tells me the channel should be 60 or 73 help
Is this a tv2 off of the primary reciver from another room?
If so there is a 2 step process to help you fox this.
Generally yes it is 60 or 73 but some installers do change it.
If it is on 60 The it will be on 60 AIR not 60 CABLE , if it is on 73 then is will be on 73 CABLE not 73 AIR..
To simplify this for you go into your tv's menu and select your air/cable type to air and have the tv do a channel scan. once complete use your remote and go up and down the channels in air mode it may find more than one. check and see if any of them are your dish box. If not then go back into the tv menu and select your air/cable setting to cable and repeat a channel scan. again once complete use the tv remote to go up and down channels untill you locate your dish box. If you do both of these and still do not have your signal verify that there is no VCR or DVD player "ON" at that location. They can be hooked up, just not on. Also some tv's have an antenna A and antenna B on the back of them , if your does make sure you test with both antenna connections. If you go thru all of this and still cannot get a signal then a line may have gotten cut or dissconnected and they need to send a tech out.
Sep 24, 2009 | Akai 20" TV
I have a Phillips PC7225 C121 ..I programmed it to a universal remote and went to menue.. it says Barker, Channel, Firmware ..I put it on channel but cant get to do anything after that...what do I do... I...
I need to add channel 66 to this tv and it only goes to channel 60.- the remote or the tv.?.
if remote doit mannuly on the tv.
if tv. .............................
Aug 06, 2009 | Televison & Video
Televison & Video Logo
56 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
