Question about Jules Jurgensen Watches
Having problem getting watch back off. Is it a pop off. The watch repairman tried popping it off with no success. A jewelry store said I needed a special tool. I am confused. I just need to change the battery.
SOURCE: removing the watch stem
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
Posted on Apr 11, 2008
diddydaveh
  • 154 Answers
SOURCE: Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Posted on Jan 02, 2009
  • 6 Answers
SOURCE: Diesel DZ1047 watch - need to replace strap
use a pocket knife and put the blade in the grove in between the strap and the steel of the case and pull towards the leather of the strap the pins are sping loaded and work simular to a miniature shower rods very simple so dont get nerves bout it if all else fails you can even just destroy them geting them out and get new pins and straps at wallmart for like 5 bucks
Posted on May 21, 2009
  • 7 Answers
SOURCE: can't put (back) back on my timex indiglo
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Posted on Aug 27, 2009
SOURCE: I have model 2701 (AMW 320R) watch. Battery needs
Yep, here it is....SR920W
Posted on Apr 26, 2010
How can I change the battery on a ladies Sekonda 4602AKT watch.
If it is indeed a screw type back it will have indentions ON the back (6 to 8). A special tool is required to remove the back without damage to the watch back. Any reputable jewelry store should be able to remove the back. If there are no indentions then it should be a pop back. Some watches do not have a slot to slide a pry tool under the back. You have to use a sharp knife..taking appropriate safety precautions.
Jul 03, 2016 | Watches
The pin that holds my watch broke. How can I have it repaired?
A jewelry store will be able to match and replace the spring bar on your watch for a minimal charge. A mom and Pop store would be best.
Apr 16, 2015 | Watches
How to take the back off of a mossimo watch
take to a jeweler with a watchmaker, or at least to a jewelry store that works on watches. You may be able to get it off, but you will never be able to get it back on!
Jul 04, 2014 | Bulova Watch
Putting the back of my watch on after changing the battery
Hi Ken,
Some watches require even pressure all the way around the back at the same time to get it to pop on! You will need to have this done at a jewelry store or watch repair shop. Thank you! Lisa
Nov 07, 2013 | Watches
DZ5164 IS THIS A BATTERY WATCH IF NIT HOW DO WE GET IT GOING ( NO INSTRUCTIONS IN BOX ?)
Yes this is a battery run watch. Do you see somewhere on the back edge that looks like a lifting spot it is usually a small indent? You can gently pop it up with a pocketknife and replace the battery. If you do not see a lifting spot you will have to take it to your local jewelry store. Thank you! hope this helps.
Sep 20, 2011 | Diesel Analog watch DZ5164 Watch for Women
Which battery will i need for dkny NY3715
if you use a small instrument, to pop the back of your watch off, look inside, and carefully, make sure you do not touch the small coil, (it looks like a copper colored tube) remove the battery, on the back of the battery, you will see numbers, such as a 370R or 385LRW that is the size of your battery. go to your local jewelry store, or sometimes, a dollar store, and get the same battery, pop it in. when replacing the case back on your watch, be really careful, sometimes there is a VERY small notch, or indent, this indicates where it needs to be positioned. if you see a notch (not every watch has this), you need to line it up with the watch stem. The notch is there to make sure you do not bend, or sometimes break the watch stem. good luck!
Jul 17, 2011 | Watches
Can't press the back of the watch back on after replacing the battery - Do I need a jewelers press?
A jeweler's press provides an equal amount of force around the edges of the watch back without putting that same pressure on the watch crystal (which could cause it to crack or break). If you have a flat crystal, you might have success in putting the watch between two pieces of wood and using a regular vice to very gently push the front and back together. However, you risk doing damage to your watch crystal.
Your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
May 05, 2011 | Timex 27191 Wristwatch
How to open the back of a wrist watch to change the battery. i have two disney watches both have red m on the litle dial you use to set the time the model numbers on back of the watches are: mu1240 mu1108...
Identify first if it is a "screw on back" or a "pop off" back. Screw on backs have multiple indentions on the caseback where a special tool fits in the grooves to twist it on and off. If it is a screw type back then you will either need to buy a pricey caseback wrench or take it to a jewelry store that changes watch batteries.
A pop off back will have a smooth caseback with no indentions on it.
Most of these are "pop off" backs. to pop the back off get a very sharp blade and apply pressure at about a 30degree angle between the case and the caseback on the underside of your watch. From there you should be able to pry it and it should pop right off. Another way is to put a razorblade between the case and caseback, tap the blade with a small hammer (lightly!) and then pry the back off.
Oct 19, 2009 | Watches
Michele ladies watch
Anyone who says they can't open your watch is NOT a repairman. Take it to a mom and pop repairman, NOT a big store, because most of the big stores send all their repairs out to someone like the mom and pop store. If you still have problems finding someone please feel free to get ahold of me and I will assist you. Good Luck!!
Jul 20, 2008 | Michele 71-750-cc-322-102l Wrist Watch
Watch
You need to go to a professional watch repairman, not just a jewelry store, or a store that claims they do the repairs, but in reality, sends them out. Any watch repairman that does the work on the premises will have these in stock, rare or not.
Apr 24, 2008 | TechnoMarine RSQC05 Wrist Watch
Watches Logo
19 people viewed this question
Top Jules Jurgensen Watches Experts
Tom Chichester
Jim Dowell
Buddy lotter
Buddy lotter
Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
