Question about Garden
Free john deere manuals
Starts to backfire only when blades are engage have cleaned out fuel system and replace filter
4 Suggested Answers
  • 425 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
  • 10865 Answers
SOURCE: my 14SB John Deere mower will start but then quits
Hello. You have some winter buildup in your engine. Get a can of starter fluid and a helper. have the helper shoot small squirts of starter fluid into the air filter while you run the mower. In just a couple of minutes the starter fluid will clear your problem. Joe
Posted on Apr 25, 2010
Why does engine die when brake is released? on a john deere riding mower
is your engine revved up when engaging the blades or releasing the brake if so i would start with the fuel filter spark plug and make sure your fuel is no more then a couple months old after that the ethanol will separate from the gasoline and cause nightmares try running a bottle of B12 chemtool carb cleaner it has done wonders for me personally both cars and small equipment
Apr 07, 2017 | John Deere Garden
John deere la145 wont turn over
Make sure the blades are turned off. If so, turn them on and off a few times to cycle the switch and see if it starts. If not, you'll have to start from the batteries and go to the fuse and check for power to and through the keyswitch until you find the place power is lost. Do you have a 12 volt test light?
The battery will need to be tested with a volt meter that will tell you how much voltage is available. The fact that it can light up a continuity tester will still have you guessing whether it has enough voltage to operate the starter.
Aug 09, 2016 | John Deere Garden
I have an '04 john Deere 737 ztrak mower and when
check for a spindle seizing from rust and failed bearings.
Jun 15, 2013 | Garden
Have sx75 and starts fine. After about twenty min it starts to cut out and die. Almost like it is vapor locking. Wrapped fuel line with aluminum but didn?t help. Installed new plug and cleaned all...
Try this.
When the machine begins to stall, immediately loosen the gas cap.
If this works, drill out the vent holes on the cap.
Please post back to let me know if this works.
Gary
Mar 08, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a john deere K series 17hp riding mower. when I try to engage the blade the safety mechanism works but the blade will not engage. the switch has been replaced.
Hi, sounds like the clutch. If you feel confident you can strip the mechanism down, clean and replace, otherwise its a new clutch.
Aug 29, 2010 | John Deere Garden
14sb engine running when blade clutch is engaged the lawnmower stalls.
Normally I believe this mower to have a Kawasaki engine, and the main jet and 'pilot air hole' need to be cleaned. You are running a lean condition, and when the blade is engaged, the engine does not have enough fuel to continue the extra load. A small test for this is to engage the blade and the choke at the same time. If the engine has enough fuel to continue running and engage the blade, this confirms the lean fuel condition. Cleaning those jets will solve the issue.
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Motor backfires
It sounds like your engine is firing out of time.
Here is a link to the manual for your engine. It does contain some good info and I hope it will help you to solve this problem.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Best of luck!
Aug 31, 2009 | Garden
John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
2,349 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
