Question about Cameras
My kodak multi card reader is displaying a orange light and is not wanting to read any memory cards
It shows up on my pc, but it will not let me use any sd cards in it. it was working fine back in september. i dont know what went wrong. i didnt do anything to it. now all it does is display a orange light, will not let me use any memory card at all in it, and trust me, ive tried every card that'll fit in this thing. help
    President:
  • 485 Answers
Card readers can malfunction for various reasons. First, try using this (USB) card reader on another PC/laptop ? If it works on another computer, then a likely problem is the card reader driver on your PC. You may want to go through a "device" test first on your PC, to make sure that the device is functioning properly. Then, locate and download a software driver (for this card reader), and install it. [ Yes, when you first use / insert the card reader into the USB port, the PC automatically will locate, download and install the driver on your PC... like any plug-and-play device.] So, if the device isn't working anymore, the driver may have been lost or corrupted. And recovering them may be possible from your backup ... when the device was still working properly.
If the card reader doesn't work on any other PC's, then it's likely that the card reader is "burnt" out. These are inexpensive circuits and (very) disposable items.
Posted on Jan 02, 2014
  • 4 Answers
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
Posted on Feb 03, 2009
  • 4090 Answers
SOURCE: memory card cannot read!!!
sometimes lapstops and PCS as well as Cameras can go out of line. That is the formatting in a particular PC may not be able to be read in another.
In you case this may not be so, as the card now cannot be seen. It would have been interesting to see if it could have read it before it was formatted by your laptop. Try another card in the camera first. If no other card can be read then the problem is on the read head of the camera.
This may be just dirt or damage, and it will have to be repaired. But try another card first as the card is cheaper than a repair.
Thanlks for using FIXYA
Posted on Sep 21, 2009
jonniewalker
  • 1031 Answers
SOURCE: Kodak EasyShare C633 not reading any SD Card
check the manual for any such thing like "memory card problem" or open the page that talks about it, it may contain useful info
usually there is a preferred type recommended to use
using a memory card that was installed in other cameras may change its format or file structure, this may cause your camera not to recognize it, try formatting the card and then install it again, most cameras have a "format" option in the menu, try it out
there might be a "reset to factory defaults" option, this may reset your camera to the way it was originally it was in, could solve it
Posted on Nov 02, 2009
  • 11967 Answers
SOURCE: kodak easyshare c613: memory card says its full
If you connected the camera to the computer with a USB cord to download your pics and then just yanked out the cord without using the "safely remove hardware" icon at the bottom right corner of your screen, the card may have been corrupted. Replace it.
Posted on Nov 10, 2009
reitann
  • 214 Answers
SOURCE: Kodak Retinar Aspheric AF 3X lost cable and no
Yes, that's one of your option but it would be better to purchase a cable compatible to your camera and download the software that supports the camera. You can get the software at www.kodak.com/go/easysharesw
Posted on Jan 12, 2010
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
My computer is not recognizing my PNY SD 1GB memory card. I can still take pictures and my camera saves them to the memory card, but when I try to transfer the pictures to my computer, it does not...
In this instance, you might want to consider either borrowing, or, purchasing and card sd reader. Some computers just don't read these cards from their built-in slots, so, using an sd card reader often fixes the problem.
Hope this helps. :)
Oct 06, 2010 | PNY 1GB microSD Memory Card
I havea kodak M340 and just purchased a 8GB sdhc memory card. I keep getting a message memory card requires formatting. I press OK, get a message formatting ... and then back to the same message, memory...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Aug 18, 2010 | Kodak EasyShare C340 Digital Camera
Memory card will not format in Kodak Z760
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    EasyShare CD14 Digital Camera: i bought kodak cd14 two days ago but when i insert...
    Hi sir =)
  • May 17, 2010 | Kodak EasyShare CD14 Digital Camera
    C190-caot be read with 2 differnd SD 4GB cards. Is
    Hi sir
    #1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    # 2 Open up 'My Computer'. You should see it under the list of available drives.
    # 3 Check its contents first to make sure that you have the right drive.
    # 4 In 'My Computer', right-click on the drive and choose 'Format'.
    # 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    # 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Mar 15, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    Memory card formatting
  • May 18, 2009 | Kodak EasyShare DX7440 Digital Camera
    When I inset my memory card into my camera it reads memory card requires formatting. What does this mean? New memory card causes prompt to format card but camera does not complete formatting successfully....
  • Feb 19, 2009 | Kodak EasyShare Z612 Digital Camera
    Memory Card required formatting
    Hello
  • Dec 26, 2008 | Kodak EasyShare Z612 Digital Camera
    Cameras Logo
    29 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
