Question about LG Dryers
LG DLE4801W Dryer Won`t dry clothes in timely manner
Any help would be greatly appreciated. I have a LG DLE4801W Dryer, Dryer turns on, drum spins as usual to dry clothes. But clothes do not get dry in timely manner. i set it for normal dry always, (41 mins), i come back an hour later and dryer is still going on and it shows 10-30 mins left. sometime dryer shuts off on its own as well. cleaned the lint area, cleaned the sensor as well which is attached right by the lint assembly. I did notice when i check the clothes to see if they are dry the heat is not sufficient. the dryer is not hot/warm. did the self test on dryer, and it doesn't show any code. vent is clear as well (i checked). i did had meter trip a month before this problem, i had to shut the main circuit completely. What could the problem be? and is there a way to reset the dryer setting? Thank you
    Scholar:
  • 102 Answers
You stated that you cleaned the vent but what most people do not realize is that pulling the vent screen out and cleaning it (and possibly even using those miraculous vent brushes to reach inside) is synonymous only removing the "tip from an iceberg".
If you are fairly confident in using some basic hand tools. I can almost guarantee that if you disconnect the dryer's power cord from the wall and remove the vent hose from the back, you are at the beginning point of removing ALL the lint from the dryer. Use a hex nut driver to remove the screws from the back of the dryer to inspect the exhaust chute that leads to the area where the vent hose is connected. (Be sure to "count the number of screws and put them into a tin can or other retaining device to keep from losing any of them). You should be able to see the entire compartment once you open it. Don't be surprised to find enough lint inside including the blower wheel to fill an average plastic grocery bag! Many dryer fires start in this area because most people do not know that so much lint collects there. I highly recommend that this easily accomplished task is done about one a year to keep the exhaust chute clean. It only takes about an hour to do the job very completely. Use a flashlight to inspect the entire area. Once you put the exhaust chute back together, test it again. I have found that this fixes most dryer heating problems when there is no error code. Doing it once a year is also good fire prevention maintenance. I am very curious about how much lint you find and if this fixed your problem. Please send me a reply. Thank You!
Posted on Jan 02, 2014
  • Tall Tiger
    Tall Tiger Jan 02, 2014
    The exhaust chute is visible once you remove the back cover of the dryer.
  • Tall Tiger
    Be sure to watch out for sharp edges once the back cover plate is off.
jsrock516
  • 5911 Answers
SOURCE: dryer takes more than one cycle to dry clothes
Did you clean the entire length of the vent ducting? Or, did you only clean the lint trap on the dryer and the exhaust vent outside? If you didn't clean the ducting as well, you may still have a clog somewhere causing your dryer to be "starved" for air. A dryer needs proper air flow to dry properly. One way to check is to turn the dryer on and go outside to the exhaust vent opening. Feel to see if you have sufficient air flow. If the air flow is weak, you have a clog. If not, you may have a high limit thermostat cutting off prematurely, not allowing the heating element to heat long enough. Check your ducting first and let me know if this helps.
Posted on Jul 28, 2007
  • 184 Answers
SOURCE: Dryer doesn't heat.
THE FIRST THING TO CHECK IS YOUR POWER. THE OUTLET HAS TWO ANGLED HOLES THAT SHOULD TOTAL 240VOLTS ACROSS THEM. THE L SHAPED HOLE IS THE GROUND AND THERE SHOULD BE 120VOLTS FROM EACH ANGLED HOLE TO THE L SHAPED HOLE. THE DRYER'S MOTOR ONLY RUNS ON 120 VOLTS ( FROM ONE ANLGLED HOLE TO THE L SHAPED HOLE). THE HEATING ELEMENT CIRCUIT RUNS FROM ONE ANGLED HOLE TO THE OTHER(240VOLTS)
THE DRYER WILL RUN BUT NOT HEAT WITH ONE SIDE OF THE CIRCUIT BREAKER TRIPPED.
IF POWER IS O.K., THE NEXT THING TO DO IS PULL THE BACK PANEL OFF OF THE DRYER. THE HEAT ELEMENT IS IN A BOX ON THE RIGHT SIDE WITH TWO RED WIRES GOING DOWN TO THE BOTTOM OF IT. IF YOU HAVE A METER, CHECK FOR 240VOLTS AT THE TWO WIRES ATTACHED TO THE BOTTOM OF THE HEATER. IF YOU HAVE
240VOLTS THERE, THE HEATER IS BAD. IF NOT, THE ROUND ITEM NEAR THE BOTTOM IS A HIGH LIMIT THERMOSTAT. IF YOU HAVE 240VOLTS AT THE TWO TERMINALS ON THE THERMOSTAT, IT IS BAD. PART #
279769 COMES WITH THE HIGH LIMIT THERMOSTAT AND THE THERMAL FUSE FOUND AT THE TOP OF THE HEATER ASSEMBLY. CHECK THE THERMAL FUSE THE SAME WAY.
IF IT IS BAD, YOU WILL SEE 240VOLTS ACROSS IT.
IF ALL THOSE COMPONENTS ARE GOOD, IT COULD BE THE TIMER, TEMP SELECTOR SWITCH, OR THE MOTOR'S CENTRIFUGAL SWITCH. YOU WOULD HAVE TO READ THE WIRING DIAGRAM INSIDE THE CONTROL PANEL TO CHECK THOSE ITEMS.
Posted on Apr 03, 2008
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
techline
  • 39 Answers
SOURCE: the gas dryer is not getting hot enough to dry
In light of everything you checked, it sounds like you have a bad set of coils on the gas valve. When they go bad, it can take a long time between cycles. Hope this helps!
Posted on Dec 08, 2009
Testimonial: "thanks-the hunt continues"
  • 39 Answers
SOURCE: Bosch vision 300 gas dryer shows error E12 evry
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Posted on Jan 19, 2011
Drying machine not working, the clothes always wet.
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Oct 03, 2014 | LG DLEX2550W 27" Front-Load Electric Dryer
I currently live in the midwest and today has been an extremely humid day (90 degrees+ and 84%+ humidity). I used our LG gas dryer (Model # DLG2241W) earlier this weekend and it worked fine. Tonight, when...
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
Please let me know if I can help further.
Jul 18, 2011 | LG Dryers
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
Currently the dryer is not drying clothes at a great rate of speed. The heat is on but it is not enough to dry the clothes in a timely manner. Please help me with a solution, I really enjoy the Maytag...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 08, 2011 | Maytag Neptune MCG8000AW Gas Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 | Dryers
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
187 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
