Question about Frigidaire Affinity AEQ6700FE Dryer
How to deactivate control lock on model LEQ1442ESO
How do I deactivate the control lock
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
Jul 04, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My mother mistakenly locked her samsung microwave. She can't figure out how to unlock it and she can't tell me what model it is. Can you help?
On a friend's Samsung (she didn't tell me her model number either), you lock the keypad by pressing "0" and then "2". Press the same sequence to unlock the pad. Maybe this will work on her model.
May 31, 2011 | Samsung MW7490 Microwave Oven
How do I deactivate the automatic door locks on my 2003 VW Passat? I wish to be able control the door locks myself with the button on the drivers side door.
you must take the car to a dealer so they can deactivate the auto locking as its set into the ecm,(electronic control module).
Feb 15, 2011 | 2003 Volkswagen Passat
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal
buttons at the same time for 3 seconds.
How It Works:
1. "Child Lock" can be activated while your Washer is running.
2. Once you activate "Child Lock", all controls (except for the Power button) will be locked
until you deactivate "Child Lock".
3. The Child Lock button will be lit while it is in effect.
Here the user manual.
Jan 11, 2011 | Samsung WF218AN Front Load Washer
I NEED A NETWORK CODE TO UNLOCK MY D500 PHONE
Here are all known special codes for Samsung phones!
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = ChAeck Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got ********)
#*7683# = Sleep variable (8)
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#9999# = Software version
*#8999*8376263# = HW ver, SW ver and Build Date
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
#*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standart
~KenjiFox
Jan 07, 2011 | Samsung SGH-D500 Cellular Phone
My Frigidaire Dryer model LEQ1442ESO beeps. I have cleaned the lint screen, intake and connectors, and it still randomly beeps. Any solution? DEP
the beep can usually indicate a stuck button.If you do not find any buttons stuck then you will need to replace the main control board.
Dec 29, 2010 | Dryers
Hey, what can I do if on a ceramic hob there is no error message but a letter "L" at each section? The control buttons don't respond I only can switch off and on again but nothing happens. Please...
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Kuppersbusch Glass ceramic induction hob...
Frigidaire dryer LEQ1442ESO wont stop beeping
We have the same model, and had the same problem. We have home warranty insurance and they sent a guy out, he said the contol panel was bad and replaced it. The control panel is like almost $400, we only had to pay $55 for the guy to come out. That was 9 months ago and now it won't heat and turns off by itself.
Sep 03, 2010 | Dryers
How to unclock my samsung cell phone
ALL SAMSUNG UNLOCK CODE.... ---------------------------
*2767*688# = Unlocking Code *#8999*8378# = All in one Code *#4777*8665# = GPSR Tool *#8999*523# = LCD Brightness *#8999*3825523# = External Display *#8999*377# = Errors #*5737425# = JAVA Something{I choose 2 and it chrashed}]/b *#2255# = Call List
#*536961# = Java Status Code #*536962# = Java Status Code #*536963# = Java Status Code #*53696# = Java Status Code
#*1200# = AFC DAC Val #*1300# = IMEI #*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts. #*2565# = ChAeck Blocking #*3353# = Check Code #*3837# = ??? White for 15 secs than restarts. #*3849# = ??? White for 15 secs than restarts. #*3851# = ??? White for 15 secs than restarts. #*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM) #*7224# = I Got !! ERROR !! #*7252# = Oparation Typ (Class B GPRS) #*7271# = Multi Slot (Class 1 GPRS) #*7274# = Multi Slot (Class 4 GPRS) #*7276# = Dunno #*7337# = EEPROM Reset (Unlock and Resets Wap Settings) #*2787# = CRTP ON/OFF #*3737# = L1 Dbg data #*5133# = L1 Dbg data #*7288# = GPRS Attached #*7287# = GPRS Detached #*7666# = SrCell Data #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while) #*7284# = Class : B,C or GPRS #*2256# = Calibration Info #*2286# = Battery Data #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10) #*2679# = Copycat feature (Activate or Deactivate) #*3940# = External loop test 9600 bps #*4263# = Handsfree mode (Activate or Deactivate) #*4700# = Half Rate (Activate or Deactivate) #*7352# = BVMC Reg value #*8462# = Sleeptime #*2558# = Time ON #*3370# = EFR (Activate or Deactivate) #*3941# = External looptest 115200 bps #*5176# = L1 Sleep #*7462# = SIM phase #*7983# = Voltage/Frequenci (Activate or Deactivate) #*7986# = Voltage (Activate or Deactivate) #*8466# = Old time #*2255# = Call ??? #*5187# = L1C2G trace (Activate or Deactivate) #*5376# = ??? White for 15 secs than restarts. #*6837# = Official Software Version #*7524# = KCGPRS #*7562# = LOCI GPRS #*7638# = RLC allways open ended TBF (Activate or Deactivate) #*7632# = Sleep mode Debug #*7673# = Sleep mode RESET #*2337# = Permanent Registration Beep #*2474# = ??? #*2834# = Audio Path #*3270# = DCS support (Activate or Deactivate) #*3282# = Data (Activate or Deactivate) #*3476# = EGSM (Activate or Deactivate) #*3676# = Flash volume formated #*4760# = GSM (Activate or Deactivate) #*4864# = Dunno doesn't work on newer versions #*5171# = L1P1 #*5172# = L1P2 #*5173# = L1P3 #*7326# = Accessory (I got ********) #*7683# = Sleep variable (8) #*7762# = SMS Brearer CS (Activate or Deactivate) #*8465# = Time in L1 #*9795# = wtls key #*2252# = Current CAL #*2836# = AVDDSS Management (Activate or Deactivate) #*3877# = Dump of SPY trace #*7728# = RSAV done# (Everything went to standart but nothing was deleted) #*2677# = ARM State (None or Full Rate) *#8999*636# = Have no clue what it is, i see 20 lines *#9999# = Software version *#8999*8376263# = HW ver, SW ver and Build Date *#8888# = HW version *#8377466# = Same HW/SW version thing ------------------------------------------------------- WORKS *#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF ----------------------------------------------------- WORKS*2767*3855# = E2P Full Reset WORKS*2767*2878# =SOFTWARE VERSIONS *2767*927# = E2P Wap Reset *2767*226372# = E2P Camera Reset #*6420# = MIC Off #*6421# = MIC On #*6422# = MIC Data #*6428# = MIC Measurement #*3230# = Trace enable and DCD disable #*3231# = Trace disable and DCD enable #*3232# = Current Mode
#7263867# = RAM Dump (On or Off) *2767*49927# = Germany WAP Settings *2767*44927# = UK WAP Settings *2767*31927# = Netherlands WAP Settings *2767*420927# = Czech WAP Settings *2767*43927# = Austria WAP Settings *2767*39927# = Italy WAP Settings *2767*33927# = France WAP Settings *2767*351927# = Portugal WAP Settings *2767*34927# = Spain WAP Settings *2767*46927# = Sweden WAP Settings *2767*380927# = Ukraine WAP Settings *2767*7927# = Russia WAP Settings *2767*30927# = GREECE WAP Settings *2767*73738927# = WAP Settings Reset *2767*49667# = Germany MMS Settings *2767*44667# = UK MMS Settings *2767*31667# = Netherlands MMS Settings *2767*420667# = Czech MMS Settings *2767*43667# = Austria MMS Settings *2767*39667# = Italy MMS Settings *2767*33667# = France MMS Settings *2767*351667# = Portugal MMS Settings *2767*34667# = Spain MMS Settings *2767*46667# = Sweden MMS Settings *2767*380667# = Ukraine MMS Settings *2767*7667#. = Russia MMS Settings *2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages *663867# = Dump Mm file #*536961# = WAPSAR enable / HTTP disable #*536962# = WAPSAR disable / HTTP enable #*536963# = Serial eable / Others disable #*53696# = Java Download Mode #*5663351# = Wap Model ID [Your Model] #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0] #*566335# = Wap Model ID [SEC-SGHXXXX/1.0] *2767*66335# = Check on which model it is *2767*7100# = SEC-SGHS100/1.0 *2767*8200# = SEC-SGHV200/1.0 *2767*7300# = SEC-SGHS300/1.0 *2767*7650# = Nokia7650/1.0 *2767*2877368# = Reset WAP Model ID to standart
Jun 15, 2010 | Samsung SGH-A877 Impression Cell Phone
Taking childlock off
This is the manual for a different model heater but maybe it operates the same way....
http://www.rural-energy.com/publications/catalog/documents/document-498.pdf
deactivate the LOCK press and hold the
button for 3 seconds until the indicator
goes off.
During normal operation the LOCK may be
activated and all controls, other than the
OFF switch, will be locked. Deactivating
the LOCK releases the controls.
If the LOCK is activated while the unit is
turned OFF, then all functions will be locked
including the ON/OFF function. If the unit
is turned OFF while the LOCK is activated,
it cannot be turned ON again until the
LOCK is deactivated.
Oct 31, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Open Questions:
See all Frigidaire Affinity AEQ6700FE Dryer Questions
Frigidaire Affinity AEQ6700FE Dryer Logo
20 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
