Question about Gigabyte GA-8I865GME-775-RH Motherboard
RAM i buy Ram 512MB also i have one 512MB after the testing memory the computer stop runing so what i do
  • Richard Eisenstein May 11, 2010
    What is the exact question/problem?
  • 729 Answers
Check CMOS battery on motherboard, it should be 3 volts. if it measure far lower, replace it!
Posted on May 21, 2009
I have a dell optiplex G240.its ram is 256 and 512mb.but now 512mb ram doesnt support.what can i do?
Well, there are many different types of Ram (Memory) available for many different motherboards. Your current computer support a maximum of 1Gb of ram. And judging from the date it was released, your motherboard seems as though it only supports DDR Ram. Therefore you may either have to buy another set of ram or buy another computer (used if possible). Although the second option is only valid if you are looking for something that is faster than what you currently have. Personally speaking upgrading the memory for an old build will not give you the best performance out there.
List of Memory Type
Ranging from Slow to fast
DDR Memory
DDR2 Memory
DDR3 Memory
DDR4 Memory
Other Thought's
Re-seating your Ram(Memory) may help get your 512MB
ram running again, however if your 512MB ram is a faulty module it may fail to work.
Aug 07, 2015 | Dell Computers & Internet
I WILL REPAIR MY COMPUTER
Upgrade your RAM into 1GB or more, currently you are using 512MB which causes your system slowdown. On that model look for SoDIMM RAM with the DDR2 slot with 1GB or more. If you can see 2 memory slots, just buy additional RAM then put it on the blank slot.
Oct 06, 2012 | Acer ~ Aspire 1.5GHz Pentium M 512MB/80GB...
Can i use ddr2 kvr800 for my pc
Product Details Kingston DDR2 800 2G Memory Ram 1).Capacity :512MB.1GB.2GB 2).Model:KVR800D2S6/2G 3).Interface :DDR2 SODIMM computer ram,memory ram,laptop ddr ram,memory module Product Description User Rating: 0.0/5 Kingston Technology Kingston ValueRAM Computer RAM 2 GB - of DDR2 SDRAM, KVR800D2S62G KVR-800D2S62G KVR800-D2S62G KVR-800-D2S62G KVR800D-2S62G KVR-800D-2S62G KVR800-D-2S62G KVR-800-D-2S62G KVR800D2-S62G KVR-800D2-S62G KVR800-D2-S62G KVR-800-D2-S62G KVR800D-2-S62G KVR-800D-, ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices. Product SpecificationsModelBrandKingstonModelKVR800D2S6/2GType200-Pin DDR2 SO-DIMM
Apr 03, 2011 | Computers & Internet
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Upgrade ram
In order to upgrade the ram of your desktop. First you have to check the ram specifications. If wrong specifications the desktop will not work. To check you have to remove the ram from your desktop by removing the screws behind your desktop. Open the lid and you will see the contents of your desktop. Besides of your processor, there is ram installed. Unclip it. Then bring that ram to the computer shops. Purchase a ram higher than the ram installed in your desktop. Afterwards, install the new ram to your desktop. Good luck.
Sep 13, 2010 | Acer Aspire T690 (AST690UP820A) PC...
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
Excelling computer memory (RAM)
If you really wanna increase the RAM level acceptance you have to upgrade *********** board. You can force more than 512mb RAM with your current system. You can use Vista in which you can connect external USB drives which can act as RAM (but only in Vista).
As of now, you can put more than 512mb RAM in your system.
Jun 29, 2009 | IBM ThinkPad A22p 2629 Notebook
Installed a new memory now computer won't boot up.
u just bought the wrong type of memory take the chip out of ur pc to best buy or a good computer store to help u buy the correct memory
Nov 24, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
1024 RAM
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
Gigabyte GA-8I865GME-775-RH Motherboard Logo
59 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
