Question about Hoover Tempo Widepath Upright Vacuum - Blue
Loud vibration Hoover Tempo
The belt on my hoover Widepath tempo vibrates, slapping against the belt channel walls. I observed this with the sole plate off. I suspect that the belt may be stretched too much, but want to rule out agitator brush problems (though does not look excessively worn or damaged).
  • 18 Answers
SOURCE: My Hoover doesn't roll
You need to replace the belt. Part number 40201160
Posted on Oct 08, 2009
Vac Belts
  • 701 Answers
SOURCE: HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Posted on Oct 20, 2009
Vac Belts
  • 701 Answers
SOURCE: my hoover widepath tempo does not pick up, the
Ya, you need to replace your belt. You can get this belt here:
Hoover Widepath Tempo Belt
Posted on Oct 23, 2009
  • 294 Answers
SOURCE: Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
Posted on May 02, 2010
Testimonial: "Thank you - it helped me look for the right source - thankfully, belt was not broken, just slipped off the hinge - but atleast i knew what to look for :)"
  • 240 Answers
SOURCE: Hoover Widepath Tempo - belt
Perhaps the belt is stretched. Replace it with Hoover belt # 38528-033. Remove the rug plate on the bottom ( 4 screws ), and remove the brushroll. Place the belt around the motor shaft first, then position it around the brush, and push the brush back into the housing. Expect resistance from the belt, as it must be stretched several inches. After the brush is in place, turn it with your fingers to be sure the belt is centered, and not pinched between the brush and the housing. After replacing the bottom plate the vacuum should be ready to use.
Posted on Feb 18, 2011
Vibrating belt
Binding roller -- streched or wrong belt--
Jan 02, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Is there a reset button on the hoover tempo widepath. I plugged it in and the on/off switch was ON, it sparked at the wall and then stopped working. Will not turn on at any wall plug in. Hoping it needs to...
canot see any mention of reset swich in manual, try renuing the fuse first, if it still does not work change the plug.cutting the cord back about 3 inches,if still no luck have it looiked at by your local repair shop.
Aug 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Widepath Tempo - belt slips off when we start it. Can you help?
Feb 18, 2011 | Hoover Tempo Widepath Upright Vacuum -...
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
Oct 07, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Burning smell
the belt needs changed. its slipping. make sure its not clogged with carpet or string ect. first. if not buy a belt at walmart. in stock...
Sep 08, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Self propel feature broke on Hoover Tempo Widepath
Sounds like the tie has loosened the belt off. You may have to check under neath the sole plate by removing screws and having a look. If the belt is broken it will have to be replaced. If its not broken check that it hasn't moved within the gear assembly of the self propel mechanism. Fit everything back together and it should work after that.
Feb 20, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Tempo Widepath Upright Vacuum - Blue Logo
49 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
