Question about Vacuums
Bissel powersteamer powerbrush
The dirtlifter powerbrush isn't squirting out water, or sucking in water from surface. what do i do?
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: The control knob for High trafic,Normal,Water only came off How do you put it back on
Never heard back from you, here is a picture:
Posted on Mar 27, 2008
SOURCE: powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Posted on Jul 05, 2009
I don't have any suction with my bissell dirtlifter powerbrush...how can i fix it?
Check the Water Tank Filter on the cap of the tank (it looks like a screen) If clogged then the tank holds air and can't suck up water. You may want to check your User's Guide to see if there are any other filters that may need cleaning after each use. Hope that helps. If not Bissell has a Consumer Care service at 1-800-237-7691
Aug 25, 2014 | Bissell Vacuums
check all you pieces to make sure it's all put together correctly. If the tank or nozzle isn't installed right it can't create suction.
Oct 19, 2013 | Vacuums
Powersteamer problems
You need to replace the pump belt. Here is the belt you need and it comes with printed instructions:
Bissell Pump Belt
Feb 03, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Powersteamer powerbrush
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
The dirtlifter powerbrush do not trun.the belt are ok and i unplug it and trun it back . still not working
I have a Bissell Dirtlifter Powerbrush that will not spray soap. I assume the soap lines are clogged, but how in the heck to you "unclog" them? I've searched high and low on the Internet looking for that answer.......
Apr 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water will not come out to do floor work
HI, I have a very similar Bissell. My problem was that after unscrewing the top plate and looking at the pipes the pipes feeding the front sprays were full of gunge blocking the sprayheads. I managed to flush it through by carefully removing the T connector that feeds the front 2 pipes, placing it back so it stuck out of one of the holes and replacing the water tank and turning on while holding it over a bucket. Black and white bits came out but it did flush through. I am thinking of doing a youtube video - let me know if this will help you!
Chessvalley.
Nov 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
