Question about ASUS Computers & Internet
Asus K55N POWERS ON NO PICTURE
POWER BUTTON LIGHTS UP AND ALL LIGHTS ARE WORKING FAN IS RUNNING JUST NO PICTURE..
  • 3 Answers
SOURCE: Acer Aspire 5050 won't power on
If anyone is still having symptoms, I have the reason behind the problem. Acer uses a power input jack made of mostly plastic with a sheath of aluminum around it. This sheath has 2 main functions first is to solder it in place on the board, the second is to provide grounding. This very delicate little box made of mostly plastic has a little center node that is broken off if the laptop is drop hard enough, usually 2 feet or more. This center node provides one side of the polarity of electricity in order to power on the laptop. Upon breakage it slips back into the laptop never to interface with the powercord again, thus no charging. I would suggest everyone to look in the hole of their power input jack and you will probably see yellow plastic surrounding a silver post that is dangling in a weird fashion.
Posted on Feb 13, 2008
vampi69
SOURCE: Hp nc 6000 wont power up
I've seen that in the most of cases is a wireless card problem. Please when you start the PC look at the blue led of the wireless network : if it is alwais on (until the pc turns off by itself) remove the wireless card located under the central cover ( 4x4cm with a cross screw). Remove and isolate the 2 antenna cable from the card. Everything will be allright ! Have fun.
Posted on Apr 16, 2009
208501414
  • 127 Answers
SOURCE: Toshiba Satellite A305D-S6848 HAS NO POWER. NO
TRY TO REMOVE THE BATTERY AND JUST PLUG THE CHARGER ON IT AND ON POWER. SWITCH IT ON. IF IT TURNS ON THEN YOU SHOULD KNOW THAT YOU NEED A NEW BATTERY OR IF IT DOES NOT, TAKE IT TO A COMPUTER SPECIALIST TO CHECK ANY HARDWARES THAT ARE NOT FUNCTIONING.
THANK YOU
WONDER
Posted on Oct 29, 2009
SOURCE: Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
dajots
  • 92 Answers
SOURCE: My ASUS Eee PC 1005P won't turn on. This had been
Try turning it on with the battery without the charger. Then try turning it on with the charger without the battery. If it still doesn't turn on either way, it's already a problem with the laptop's motherboard. If your laptop is still in warranty, you should have it serviced. Otherwise you need to bring it to a repair technician.
Posted on Apr 04, 2011
I need a repair manual for asus k55n?
To get a repair you need to go on this following website: http://www.searchall.com/search/topic/g?utm_source=adwords&utm_term=repair%20manuals%20online&id=3MDMxgDO5YzMx0CNtIjM5AjMxQjM&gclid=CJDElNSG5r4CFaY-MgodRAcALA
Jun 06, 2014 | ASUS 15.6" K55N RIN4 Notebook PC w/ AMD A8...
Had my motherboard changed by local repair shop. Both fans are now running constantly & it is deafening, also power light no longer comes on and was told it was "no big deal". Have 2 like computers,...
Ok so what fans? the case fans? the cpu fan? The power supply fan should always run. The case fan can be wired to the mother board and do an speed step system (slow to fast) depending on heat, same with cpu fan. As for the power light its just an matter of pluging in the wire from frount panel to the mother board pins for pwrled. Asus has an download for your board to get the pin outs.
http://dlcdnas.asus.com/pub/ASUS/mb/socka/sis741GX/e1766_a7s8x-mx.pdf
Feb 25, 2010 | ASUS A7S8X-MX Motherboard
Asus P4P800S-X IS RUNNING LCD SCREEN IS BLACK
First thing is check the monitor by replacing it with any working monitor. If that does not work remove the Graphics card and do the same. The problem will be either in the Graphics card or the monitor....sodeep
Apr 09, 2009 | ASUS P4P800S-X (610839118175) Motherboard
ASUS P4-533 won't power up.
Please disconnect all the connectors and put them one by one and try following DYI
1.Refix the connectors and the check the power is coming.
2.If the power is coming in the machine and the fans are moving then the issue is with the RAM refixing open the cabinet and then refix the RAM module and it will work.
Feb 19, 2009 | ASUS P4-533 Terminator (terminator p4)...
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
ASUS A8V-VM MOBO
To turn your computer off, hold the power button in for 6 to 8 seconds. I would disconnect the fans you installed to see if you are loading your power supply. If you install a video card take it out and in a couple time to clean the contact, with the power off.
Oct 11, 2008 | ASUS A8V-VM Motherboard
Asus k8v-mx motherboard
BIOS of your motherboard is crashed. M/B needs to be replaced
Jan 12, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
13 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
