Question about Mitsubishi WD-65735 Television
Mitsubishi wd-65735 new lamp picture still dim
SOURCE: I just replaced the lamp on my Mitsubishi WD-62327 picture is dim
TAKE THE FRONT SPEAKER PANEL OFF AND YOU WILL SEE TWO SCREWS ON THE LEFT AND RIGHT TOP CORNERS THAT HOLD THE TABS FOR THE SCREEN LOOSEN THEM THEN GO BEHIND THE TV AND REMOVE THE SCREWS AROUND THE PARIMETER OF THE BACK OF THE SCREEN 10 TOTAL THEN REMOVE THE FRONT CENTER PANEL 4 SCREWS AND UNPLUG THE SCREEN EASY TO SEE WHICH ONE THEN JUST LIFT THE SREEN STRAIT UP ONCED REMOVED YOU CAN CLEAN BOTH MIRRORS DONT USE CHEMICAL CLEANERS JUST A SOFT RAG HOPE THIS HELPS
Posted on Jan 25, 2009
  • 668 Answers
SOURCE: replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Posted on Jul 17, 2009
localwonder
  • 6784 Answers
SOURCE: wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Posted on Sep 02, 2009
phil_frye
  • 295 Answers
SOURCE: Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
Blessings,
A/V Media Guy
Posted on Nov 20, 2009
Testimonial: "very helpful. this was my first thought! thank you!"
  • 1121 Answers
SOURCE: mitsubishi tv very dim picture, new lamp already
need to replace the inverter board also
Posted on Feb 18, 2010
Why would a Mitsubishi WD-65735 Television turn on and have sound but no picture?
have you pulled the lamp out & checked it. It is possible you have gotten poor quality lamp. It is critical on a mitsubishi to get the proper lamp.
Lamp-Cartridge 915B403001
http://www.shopjimmy.com/mitsubishi-915b403001-dlp-replacement-lamp.htm
May 08, 2014 | Televison & Video
My mitsubishi WD-65735 1080P has a green blinking light under the word lamp..what does that mean?
all these sets have a boot up if unplugged.
If power is lost or disconnected when reconnected green light will blink for about 70 seconds (set is rebooting) and then go off allowing set to be turned on.
Questions?
Mar 12, 2012 | Mitsubishi WD-65735 Television
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
I have a wd-65735 and the picture is week even with the brightness up all the way. do i need a new tube? Thank you
It is likely you need a lamp. Go to http://www.pureglare.com for best price. A lamp is needed especially if you have no discoloration of the picture. Accessing the lamp is easy by locating the access panel usually on the back of the set. Remove the door then the lamp with its housing. Inspect the lamp carefully and see if there are any bulges at the base of the filament in the center of the lamp itself. If so it is weak.
May 19, 2011 | Mitsubishi WD-65735 Television
When the tv goes out can you purchase just a bulb or do you need to buy the lamp
you can't buy just the bulb
http://www.discount-merchant.com/Mitsubishi-915B403001-Lamp-DLP-TV-lamp-p/mitsubishi-915b403001-lamp.htm?1=1&CartID=0
Jan 25, 2011 | Mitsubishi WD-65735 Television
The color is really dim,
i have a wd62528 62" dlp hdtv that shows a picture but very dim. I have tried numerous things including factory reset and checking the lamp. I started to get a new lamp but was told if i have a dim picture getting a new lamp will do nothing. However, Mitsubishi support said that if i have a dim picture but was not continuing to get worse or darker, then they were 100% sure i just needed a new lamp. I'm confused. Will a new lamp solve my problem or no. i would just buy and try but it is very costly. please help
Nov 02, 2010 | Mitsubishi WD-62528 62 in. LCD Television
My two year old WD-65735 TV's screen is hard to view unless we turn up the brightness and turn off all the room lights.
Time to replace the lamp. If it been at least two years then its time for a new one... This will restore brightness level of the picture to normal. Also while back there make sure you clean any clogged vents or filters.
Nov 28, 2009 | Mitsubishi WD-65735 Television
Mitsubishi WD-65735 Television Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
