Question about Nuova Simonelli Oscar Coffee Maker, Espresso Machine
Steam nozell is pluged
Yes i have the nova professional  ,  black machine  but now no  steam  or water comes out of steam nozzell  chris
    President:
  • 1,618 Answers
When you open the knob is the wand hot? If yes then the holes at the end of the nozzle is plugged, use a paperclip or needle to clear.
Posted on May 22, 2009
SAND LIKE SUBSTANCE COMING OUT OF IRON
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store.
To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out.
Hope this helps...
Jun 29, 2012 | Rowenta Perfect Iron
Flakes/Particles coming out of the steam nozzle.
hi there,
the small flakes are bits of lime scale from your boiler system, to fix/ reduce flakes/particles complete a de-scale cycle on your machine using de-scaler. water hardness- set on 1 will change the length of time before it will ask you to de-scale the machine. Note- hardness 1 is the max time length. hope this helps
Feb 23, 2012 | Saeco Royal Professional Espresso Machine
The mop just stopes making steam to the head. Could this be A heat coil problem? Also a lot of others have had This happen.
On these steam mops, you have to use distilled water, if you use tap water and do not have a house water softner or some kind of water filtration system, the water running thru the tubes of the steam mop
will develop calcium deposits, these deposits are caused by hard water and will clog up the tubes, and keep the mop from producing steam, then you will have to replace the lines. i own this brand of steam
mop and had the same problem you had, I replaced the lines and started using distilled water, and have not had any problems since and that was last year. good luck!
Aug 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Very little steam, it seems pluged up
yes' it sounds as though it is plugged,, try and do a descaling -- to do this add about a cup of white vinegar to the water and let it steam out,, you might also need to do this a second time and then do just a fresh water steam.
c...
Mar 03, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Low pressure from steam wand
It sounds like calcium has built up in the machine. Try running pure vinegar through the machine a couple of times. Hopefully that will clean out the calcium and it will start working again. I had the same deal with a coffee pot that took forever to run the water through. After two sessions of vinegar it worked like new
Jul 01, 2017 | Breville ESP8XL Espresso Machine
Saeco Royal -No water is coming out of milk frother and water underneath machine
Yes- specially if you see "white scaling around it". If machine not regularly descaled, this can happen. For part and or customer support contact
Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 04, 2008 | Saeco Royal Professional Espresso Machine
Where to fix my Gaggia
If you are unfamiliar with semi-automatic machines you might have neglected to prime the machine: open steam valve with a small container at the nozel, press coffee delivrery button and wait til water runs into the container,the close steam valve and water should come through shower head. This is very basic. If no solution then the head group might be jammed with old coffee grinds. See coffeegeeks forum on subject.
Dec 30, 2007 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Nuova Simonelli Oscar Coffee Maker, Espresso Machine Logo
110 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
