Question about Pool & Spa
My pump not being able to pump the produced fresh water
My pump not being able to suck and pump the produced fresh water
    Problem Solver:
  • 7 Answers
Are you saying your pool pump will not pull water?
Posted on Jan 03, 2014
2012 keystone alpine 3500RE replace fresh watercheck valve
If I'm reading your question right, you're talking about the check valve at the city water inlet. Without that valve your onboard water pump just sucks air, no water. Easy fix. Just buy a garden hose shut-off. The little one with a ball valve. Install it on the city inlet in the closed position, solved. When you at a location with city water, connect you hose and put the valve in the open position.
Mar 07, 2017 | RVs
I have a keystone springdale 311ressr. My water pump is under the carpeted step by the bedside stand. There is no access panel that I can find. How do I get to it to winterize?
Drain the supply tank (or run the pump until it sucks air) then pour a little RV potable antifreeze into the supply tank, open each faucet/outlet -- one at a time -- and run the pump until antifreeze appears at that faucet, close it and go to another one until all are running antifreeze - they color it to make this easy. All piping and pump and tank is now full of antifreeze and protected. In the spring put a little fresh water with a dose of chlorine bleach in the tank, run that through all outlets, fill tank with clean water and run that until you can't smell chlorine. System is clean and ready for use.
Oct 19, 2016 | RVs
Freshwater tank fills and overflows even though selector is pointed at 'city water' position.
Other than a leaking 4 way selector valve the probable cause would be a leaking check valve in the pump.
On the RV the city water and discharge from the fresh water pump are tied together. When on city water the discharge of the pump will have city water pressure on it. If the internal check valve on the pump is leaking, water will flow through the pump backwards and into your fresh water tank.
Typically this requires ether replacing the pump or installing a secondary check valve between the fresh water tank and the pump suction.
Oct 28, 2015 | Keystone 2013 Alpine 3720FB
How do you get mold out of fresh tanks?
There should be a fresh water fill on the outside of the coach. If not then there is a valve that would need to be turned that will allow water to be put into the fresh water tank. If that is the case then it will be a bit more difficult to put bleach into the fresh water tank but not impossible. There will be a pump that draws fresh water out of the tank. You can disconnect the input and output lines. Connect the input line which comes from the fresh water tank to the output side of the pump. Then using a flexible line with a 1/2" pipe thread fitting, connect that to the input side of the pump. Put the loose end of the flexible line into a gallon of bleach and turn the pump on. It will draw the bleach out of the container and pump it into the fresh water holding tank. Now return the plumbing of the pump back to the original configuration. Using the valve system complete filling the fresh water tank with fresh water and allow to sit for a couple of days. Then open the low point drain on the fresh water tank and completely drain. When the coach is not in use make sure the tank is completely drained. There is also a fresh water treatment that you can purchase at your local rv parts department.
Jun 13, 2014 | KZ Coyote Rock Climber CRC220 RVs
My fresh water pump's suction poor
check the lintpot on the pump.. look in there and see if debris is blocking the impeller opening..see if any pipes to it are blocked up or if its sucking air anywhere..
Jan 02, 2014 | Pool & Spa
Machine turns over, but keeps stalling when I begin to spray
By stalling you mean quit or bogs down until you release spray?
The engine has to be on high speed and be in good tune with good gas to produced the horse power for the pump. A too small water supply hose can add to to the engine load trying to suck water that is not there.
Sep 12, 2013 | Dewalt Garden
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
Just set up a recently purchased used Astoria argenta single and can't get a thick Espresso
Try adjusting the grind on the grinder to a finer setting, and make sure that the machine ins producing about 9 bars of pressure on the water pump(check bottom gauge on manometer).
Feb 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Got some problems with my hho
The HHO generator uses low DC voltage to produce Hydrogen and Oxygen from water.
Fresh water isn't the best conductor of electricity so an electrolyte of some sort is usually added to the water.
A safety tip: This was probably included with your unit, but it doesn't hurt to cover it again.
  • Wear safety glasses, good ones.
  • Dont smoke or have any ignition source while checking the unit. HHO is produced at the optimum ratio for combustion, and by that I mean COMBUSTION. This is the same fuel in the same ratio in that big orange tank the space shuttle rides on. The slightest leak can be dangerous. Be aware of this. Ok?
A side effect of these units is they produce heat. The water gets pretty hot, not boiling, but hot. That would be a way to see if its working.
You haven't described the unit, volume of water and electrolyte used. That would be helpful.
As a rule, if the plates are covered in water, if the electrolyte has been introduced, if it has power then it's working and you won't notice any difference at all.
Unless the unit you got is the super deluxe multi-cell model, the volume of HHO produced per minute is only a small percentage of what the engine is sucking in. It's not going to supercharge your engine. It will however enhance the combustion of the gasoline, making it burn more efficiently while adding some combustion of its own.
Hopefully you kept track of your mileage before instrallation. Keep keeping track of your mileage and compare notes. That's when you'll notice the difference.
That difference will depend on the volume of HHO produced. That depends on the electrolytic agent, volume and temperature of the water.
I hope this helped somewhat
Mike
Jan 24, 2009 | 1995 Ford Aerostar
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
Pool & Spa Logo
73 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
