Question about DeLonghi Heating & Cooling
Replace lime scale filter
Where can i buy a replacement lime scale filter for the PAC WE125 model air conditioner?
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
  • 86 Answers
SOURCE: broken wheel roller on a PAC-121 portable air conditioner
Yes, you can. The caster part number is 2040-0142 and can be found at some online retailers.
PartsGuy.com
Appliancefactoryparts.com
Posted on Feb 18, 2009
SOURCE: delonghi PAC F10 air conditioner doesn't seem to be cooling
It could well be low on refrigerant, as well as a multitude of other possibilities. I'd have it serviced by a pro.
Posted on May 07, 2009
SOURCE: pac 35 split air conditioner not cooling
Could be:
- low on refrigeraant
- loose/burned/corroded compressor electrical connections
- bad compressor run capacitor
- tripped/bad breaker in main service panel
- faulty controller components/relays
- other...
If you don't have significant experince with similar appliances/systems a service call is in order.
Posted on May 08, 2009
My water container has black fungus ,Icould'nt clean it and I'm afraid to use it.
get a filter from repeatable store.. if i may where's one i recently bought one works good.
Water Treatment
Jul 17, 2016 | DeLonghi Pinguino PAC-700T Air Conditioner
Tip
Air Conditioner User Manuals
Air Conditioners:
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:Download
or Via their contact page (depending on your country):Download
De' Longhi
De' Longhi PAC A120E Portable Air Conditioner Download
De' Longhi PAC C120E Portable Air Conditioner Download
De' Longhi PAC T110P Portable Air Conditioner Download
De' Longhi PAC WE125 Portable Air Conditioner Download
on Jun 08, 2011 | Heating & Cooling
PAC L90 air conditioner keeps frosting up. The room air intake frosts up completely, blocking all the air.
Air conditioners frost up when there is a lack of air flow. Clean the filter, check if a belt is broken (if any), check that the fan spins freely, check all in ports and out ports for blockage and clean the coils with mild soap and water.
Jun 08, 2016 | DeLonghi PAC L90 Portable Air Conditioner
I need a filter or a delonghi pac 75
The filter in your unit is washable and can be used over again and again, unless it has been damaged or destroyed.If that's the case you can purchase one from Danby Parts 1 (800) 865-6330. Have the correct Model Number handy when you call.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | DeLonghi Pinguino PAC-75 Air Conditioner
How to change or clean the filter and where to download a manual
DeLonghi has the manuals for their portable air conditioners here: http://delonghiusa.com/support/product_manuals/5#table-jump . The direct link to the PAC C120 manual is http://delonghiusa.com/support/sites/default/files/product_manuals/m-PAC+C120.pdf .
Before cleaning, turn off the air conditioner. To clean the filter, pull it straight up from behind the top of the air intake (on the back of the PAC C120). Vacuum off the filter. If it is very dirty, immerse it in warm water and rinse several times. (The water should not above 40 degrees Celsius (104 degrees F)) several times. Then allow the filter to air dry. Slide the filter back into the air conditioner and turn the unit back on.
I hope this helps.
Jul 17, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Selonghi pinguino super pac 26 works fine for about 20 min the turns off with the warning light that is the same as the power light flashing. How can this be fixed as apart from that it is fine. I did...
I had the same problem. Except it only lasted 10mins. It turned out that the water pump was not moving enough (any actually) water to cool down the heat exchange unit. The unit turns off if it overheats. I pulled the back off and realised that the water resevoir container was full of lime & calcium scale. Some of that had obviously got into the impeller blade in the water pump. I removed the water pump & hose and discovered a lot of hard crud in there. Cleaned it out, reassembled and hey presto the water was flowing agin and the heat exchanger was happy. Problem Soved. Anthony
Nov 21, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Broken wheel roller on a PAC-121 portable air conditioner
PartsGuy.com
Feb 18, 2009 | Comfort-Aire PAC-121 Air Conditioner
Contact Center
8am – 8pm EST
Feb 14, 2009 | DeLonghi Pinguino PAC-210 Air Conditioner
Hi
You need to go here
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi PAC 02 A?C
http://www.delonghi-accessories.com/item.asp?modelnumber=9824000005
or call 1-800-865-6330 and order over the phone. I just did, $65 including shipping for ONE exhaust host.
Jul 07, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Heating & Cooling Logo
110 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
