Question about Whirlpool GEW9200L Electric Dryer
Whirlpool dryer GEW9200L thermistor part number
dmftrucker
  • 1922 Answers
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
Posted on Oct 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet GEW9200L control
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet electric dryer
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet electric dryerGEW 9200 L --no heat
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
TheMobilian
  • 8220 Answers
SOURCE: Need part number for thermistor for whirlpool Duet
Number 42 mounts on the blower housing right beside the thermal fuse
1ee95b6.jpgThe price is decent less than $20.
This video shows how to replace it:
Posted on Oct 13, 2010
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
We are getting the code E1 on are Duet Dryer can you tell me the problem
HI, This code is in reference to the thermistor that is mounted on the blower housing inside the unit. The unit will not operate properly when the E1 code is active. The necessary actions are to replace the internal monitoring thermistor. Once that is replaced, the unit will return to its normal status.
Sep 26, 2010 | Whirlpool GEW9200L Electric Dryer
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L not heating up, i have replaced th thermal fuse, thermistor, heating element, thermal cutoff and high limit. What next.
Oct 05, 2009 | Whirlpool GEW9200L Electric Dryer
My colthes dry a little then E1 flashes, what is the problem?
HI, the Thermistor is stuck open. you will need to replace this failed part asap. this will fix the issue and, restore your machine.
(E-1-- Open Thermistor)
Jun 08, 2009 | Whirlpool GEW9200L Electric Dryer
Duet dryer makes noise while starting
Your belt or idler pulley may be defective. Click on link below and enter your model number GEW9200L into the model search feature, We also offer free assistance and help to your answers.
Click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
22 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
