Question about LG KG800 Cellular Phone
LG TG800 when connecting my phone to my laptop, it seems I can't get it to sunc nor to read my phone or SIM, What is the problem? driver? settings?
Where i can find a software of LG tg800 chocolate.thanks
amirposka@hotmail.com
Posted on Jun 14, 2008
    Sergeant:
  • 452 Answers
U need proper driver of ur phon, only then u will able to sync it with laptop,, u pliz arrange these from lg service centre.
Posted on Oct 19, 2007
  • 490 Answers
   ur problem  is not so make it clear that  r u connecting via bluetooth device or cable..if u r connecting via Bt device than frst u need to pair ur hndset with Bt device & if ur connecting via cable than there might be problem with cable drivers..& make it clear that r u  using it for internet purpose or just data transfer, & if u r trying to connect for net purposes than u definitely need to do some setings on ur mobile & pc..that are to be provided by ur service provider & rest for data transfer there is no need of setings than there might be the problem with the hardware u r using.
Thanks
gizmo1
SOURCE:
How to openline my nokia 6300???I'm from Philippines my problem was my nokia 6300 cant read other sim card.what should i do??please help me??tnx..
Dear user
As you are saying Phone cannot Read SIM card. It may be Damage to
  • Sim card
  • Sim Card connectors
  • Sim card ways
  • Sim Card IC
OR If there is asking for any Code, Enter your Lock code in case of you entered Restriction code to Sim Card in security Option . Other wise it seems to be a Sim card provider Lock. It needs to be unlocked by an Expert.
Let me know if you need further assistance...
Thanks for Connecting FixYa....
Jul 24, 2011 | Computers & Internet
How do i copy my contacts from xperia mini to another phone? there is no option of saving to Sim or exporting...pls suggest a solution as i have around 350 contacts
hi,
Just try this
1) Insert a memory Card
2) go to contacts -> Settings
3) select option backup to memory card
4) insert the memory card in another new phone
5) select option restore from memory card from contact settings
other wise you may sunc with google contact Sync option with two phones
check this link
i think it may be helpful to you
Jun 02, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My Blackberry curve 8520 DOES NOT DISPLAY y caller id's on incoming calls. These contacts are on my phone and do display when I receive a message but not when I receive a call. What can I do to rectify...
hi jenny202 You need to go into the phone section hit the bb menu key and set the display to all . Also if yout using a gmail on the phonr iy will sunc your contacts to your gmail and not sidplay then on your phone. You will need to look at the the settings .
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Dec 06, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do i un freeze my samsung star s5233s
to unlock phone turn it off remove sim card then turn back on go to menu settings , phone settings , then pc connection select pc studio, now connect phone to computer using original usb cable, wait until drivers are installed (keep in mind your sim card must be out this whole time)
if you are prompted for a driver, get it instantly at www.fastgsm.com/download set up an account or fill out your user name and password if you already have an account
click on "Read unlock codes" and wait until unlock codes are displayed write down your "unlock code" and " network code"
disconnect your phone put your sim card back into phone turn phone on
phone will ask for sim code enter your unlock code here after doing so it will ask for your network code type this in next and congradulations you have unlocked your samsung star
good luck and i hope this works for you
Jul 24, 2010 | Samsung Star GT-S5233 Cell Phone
My sciphone is reading my sim card but cannot make call. I am able to access all phone numbers on it but I cannot make calls. Do I need to set up the network somehow? I have AT&T with full bars on my...
Hi,the problem is obviously from the network settings on the sciphone,here is a solution,
1,Try to re-insert the sim card in the phone.
2,Go to the mobile connections on your sciphone and ensure the radio(service) connection is switched on.
3.If after these steps,the problem persists,then it seems your sciphone has a network problem which can only be fixed by a mobile phone engineer.
Take care
Mar 18, 2010 | Cell Phones
MICROMAX Q5 MOBILE PHONE with pc
I am posting all the steps which I did to connect my Micromax Q5 phone with my PC for Aircel Internet.
In my Q5 phone:
Menu -> Settings -> Connectivity -> Data Conn. -> GPRS -> ADD ->
APN: aircelweb
Username: Blank
Password: Blank
HTTP ->
Authentication: Normal
Proxy: No
Then next step:
Menu -> Services -> WAP -> Settings -> Select SIM -> SIM 1 -> Profile -> SIM 1 -> aircel net -> Activate Profile.
Then I can use Internet through my Opera Mini & also throgh WAP homepage.
Now I have insert CD -> Installed -> ''Installed Driver.exe''
Its showing Driver Installed successfully.
Next I opened Phone suite -> then gone to Blue icon in the Phone suite folder -> Click on settings -> General -> select port -> COM 1 -> Create connection -> Create/modify ->
APN: aircelweb
Number: *99#
Username: Blank
Password: Blank
New-> Create Connection -> Connection successfully ->
But now what I need to Do?
or Did I mistake anywhere?
Mar 18, 2010 | Lands Phones
We insert sim card in cellphone, even though the cell phone dispaly "please insert sim card"
It seems that your cell phone is having trouble reading the SIM card. You have two options. First you can attempt to clean the SIM contacts on your device. To do this simply apply a small amount of alcohol to a Q-tip and gently rub over the gold contacts where the sim card normally goes, this will help to remove any dirt build up and provide a better connection. Second, contact your service provider and request a new SIM card. Sometimes SIM cards can go bad similar to a memory card failing. A new SIM card maybe all you need.
Nov 24, 2009 | Motorola Mobility L6I Cellular Phone
I have a creative zen when i plug it into the computer, the computer wont reconise it and the zen reads clean up
hi,,not sure if u have tried this yet ,,,but open up windows media and sunc the zen,or change the setting on the zen in windows,as a portable device,,,if that doesnt reconise it, u have to reinstall the zen driver disk,,and click on full install instead of recomended installation,,
Dec 18, 2008 | Creative Labs Zen Micro MP3 Player
Phone problems
I have had a new orange sim card for my SonyE W850i, however the new sim card isnt connecting to the phone (i think). I have noticed that the new sim card has a smaller 'chip?' on it. Could this be the problem. I have tested both the phone and the sim card on phones/ sims and they seem to work fine, just not when they are together. It seems as though they are incompatible (the phone is an orange make so there should be no problems there). The phone sometimes reads 'insert sim'. athough other times it works ok but then for no reason it breaks down to 'insert sim' again.
Mar 09, 2008 | Sony Ericsson W850i Cellular Phone
LG KG800 Cellular Phone Logo
146 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
