Question about Water Heaters
My Ruud PE2-52-2 RuudGlas Pacemaker water heater is leaking water at the bottom.
Slow leak.
  • 2976 Answers
SOURCE: Slow leak drips from bottom of 4 year old model
You can probably repair this by removing the fittings and replacing any plastic compression rings with new ones. Everything else can be cleaned with grade "0000" steel wool. This will get rid of any deposits without damaging the surfaces. ! or @ careful wraps of Teflon Tape to the MALE threads will help get a good seal.
Posted on Feb 04, 2009
rylee_smith
  • 8619 Answers
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 07, 2009
  • 10865 Answers
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
Posted on Apr 27, 2009
  • 252 Answers
SOURCE: Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
Posted on May 24, 2009
co7196
  • 3433 Answers
SOURCE: My Atwood Hot Water Heater leaks when I turn the pump on.
Where is it coming from? It would make sense to have a plug in the conwe of the tank. Need you to clarify what it is lthat is leajing.
Posted on Jun 15, 2009
I am looking for magnesium anode rod for an electric Ruud pacemaker 10 gallon water heater model# PEP 10-1 and serial # 0598304245. Do you know the parts number? Bill
no
try contacting the manufacturer for the part or talk with a plumber supplies shop ( where plumbers get their supplies and parts ) to see if it is available
it will be a sacrificial rod to prevent the tank from corroding out especially around the heating element fittings
Jan 29, 2017 | Water Water Heaters
Ruud hot water heater
Best thing is to replace it as it might be rusted inside in the bottom
Dec 07, 2013 | Water Heaters
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10...
sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Dec 01, 2012 | Water Heaters
Drain valve plastic slow leak 81V-80D
If the drip is coming out of drain valve: Put a hose cap over end of drain valve.
If water is seeping out of cracked drain vale, then replace it.
If the leak is seeping around previously sealed threads, then tank may be rusted beyond repair.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
http://waterheatertimer.org/Leaking-water-heater.html
Oct 06, 2012 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
How to drain ruud pacemaker water heater
Turn off water, turn off power, drain tank:
Copy following link for illustrations
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Aug 26, 2012 | Water Heaters
My Rhem Ruud G76-200 water heater leaking from below? Can this be repaired?
If it is actually leaking from the bottom of the heater, then it cannot be repaired. Have you looked to see exactly where the water is coming from? Sometimes a leak at the top of the heater, will then leak through the insulation and out the bottom. Another possible source could be from the temperature/pressure relief valve leaking and coming out of the down pipe that goes near the floor or drain. Try to find the source of the leak. It is not practical or safe to repair a tank that is leaking.
Oct 03, 2010 | Rheem Tank Water Heater G76-200, 76 Gallon
Water leaking
Hello All tanks eventauly leak and cannot be repaired.Good thing it is slow!
Apr 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
288 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
