Question about Kitchen Ranges
Need to replace thermostste in two oven gas oven Zanussi model HCF/G810 1610
  • pvb7 May 21, 2009
    I need to know where I can get the part, thanks
  • 3,230 Answers
Servicing Oven Thermostats
If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about 25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Good Luck
Thanks
Posted on May 21, 2009
  • Mukesh Kumar May 21, 2009
    Ok... You can oder parts from
    www.repairclinic.com
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
Hi, I have a zanussi gas oven, the fuse has blown a number of times. it then cuts off ignition and there is no gas in the bottom oven. not sure if any one can help because im left clueless...
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 27, 2015 | Zanussi Ovens
Can the Zanussi oven, set for LPG, model ZCG660GXC be converted to be used with natural gas?
Zanussi ZCG660 Manuals
EW 1200 i on manualslib.com
Dont know if you have a manual. On page 21 it says:
Gas Category 13+
Gas Supply G30/31 (3+) -
28-30/37mbar
page 22 shows more settings 20mbr for natural gas
however instructions are not valid in all countries.
I went to www.zanussi.com it asked pick country and Egypt I picked. There is a support tab see if that gets you closer than Italy or Switzerland.
Good Luck looks like a great oven.
Zanussi Start
Mar 31, 2015 | Zanussi Kitchen Ranges
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
The bottom oven dosen't heat up yet the fan and the light still works. The model is Zanussi ZU270F.
You need to replace the oven element, located behind a removeable panel at the rear of the oven compartment.
Aug 07, 2010 | Zanussi ZHF470 Electric Double Oven
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
I broke the glass outside on the door of my Zanussi oven ZOB 646 QX model. The price of this glass together with the panal costs about 1/2 of the oven price. Can I replace this glass without buying the...
In my experience of repairing ovens, it is usually possible to replace glass without going to the expense of replacing whole panel.
Check with the manufacture.
Hop this helps.
Dec 05, 2009 | Zanussi ZHQ575 Electric Double Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Please rate my solution.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Thanks.
Nov 10, 2009 | GE Ovens
Noisy fan
The fan works in a very hostile environment of heat. It draws some cooler air from the rear of the oven, but essentially it is working in high temperatures, so bearing do wear out and motors seize. Removal is generally from behind the oven from the rear of the stove. The fan is on a shaped spindle and has a locking allen key grub screw, or the fan blade is pinched between two washers.
See the link for videos on how to replace and for spares themselves. Make sure they are model specific.
zanussi oven replace fan Google Search
Feb 02, 2018 | Zanussi ZCM611X Dual Fuel (Electric and...
Open Questions:
Kitchen Ranges Logo
185 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
