Question about Breville Toaster Ovens
Where can I get my oven fixed?? The backlight is not working and the door hinge is broken. Contact me at rosie1@pathcom.com
How can my toaster/convection oven be fixed....the door hinge is not working and it can cause an injury and also the backlight no longer works....have to use a flashlight to see the panel ..... very annoying.
cactus bob
  • 267 Answers
SOURCE: Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 31, 2009
SOURCE: toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
cactus bob
  • 267 Answers
SOURCE: Upper Heating Elements for Russell Hobbs Digital Convection oven
sorry to say its dead .this is the fate of all todays small appliances the only part i have in the book is a rack .no inside parts are made...hope this helped some ..........if this answer has helped and you plan to rate it please rate it a 3 or 4 star this high rateing will help me keep my spot in the paid answer department thank you
Posted on Apr 02, 2009
SOURCE: ''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Posted on Jun 30, 2010
SOURCE: setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Posted on Jan 11, 2011
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
What type of adhesive should I use for the door on a Farberware T4800 convection oven?
You need a tube of permatex blue or black RTV silicone.
I reglued my door about three years ago and it is still holding. Trick is to clean all parts PERFECTLY first using steel wool, a flat 4-sided file, etc.. Then clean real good with acetone (outdoors cause its explosive and toxic). After acetone dries do it again and wipe it dry with a piece of cotton jersey. Then reattach the hinge or handle sides using the silicone and tape it with blue masking tape. Let cure for 48 hours. You will have a joint as good or better than the factory joint.
Oct 15, 2011 | Farberware T490C 1500 Watts Toaster Oven...
I have a brand new Euro Pro Toaster Oven, Model # TO176. After a week of use a pin or similar piece fell out of the door hinge, and the door keeps falling out on the right side. The left side is still in...
My mother had/has the exact problem right down to the teapot. I am in the process of fixing it, but don't have time to post solution right now. I will post later today. I should probably post a video as it is not real simple.
Oct 26, 2010 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Door won't close
Lose hinge? Tighten it with a plyer.
Apr 02, 2010 | Krups FBC412 1600 Watts Toaster Oven with...
Our CTO650 toaster oven dosn't toast, but the oven works fine. How do I get into it, and can this problem be fixed?
I called the 800 number on the instructions (800-231-9786),. I suffered through a confusing phone tree AND a 10 minute wait on hold. I was told that my 3 year old toaster oven is "fairly old" and that parts are no longer made for it.
Very frustrating. I expect a toaster over 1) to work and 2) to have parts available for 10 years after I purchase it. The ideas of a toaster oven as a "consumable" has terrible implications for our environment.
Feb 01, 2010 | Black & Decker CTO650 1500 Watts Toaster...
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Toaster oven door
Try sales@semenedis.com They do thousands of parts for white goods.
Dec 03, 2008 | Black & Decker CTO9000 Dining-In Toaster...
Farberware convection broil oven modle T-4850
I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
1-888-464-0797.
Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Toaster oven
THERE IS A SAFETY MECHANISM ATTACHED TO THE DOOR THAT TURNS OFF THE OVEN WHEN YOU OPEN THE DOOR. INSIDE, BEHIND THE KNOBS THERE IS A SPRING THAT ATTACHES TO A WIRE THAT IS CONNECTED TO THE DOOR. WHEN THE DOOR OPENS THE WIRE RELEASES THE SAFETY MECHANISM AND THE OVEN SHUTS OFF. WHEN CLOSED THE WIRE PUSHES AGAINST THE MECHANISM AND THE OVEN WORKS. I WAS ABLE TO FIGURE OUT HOW TO RECONNECT THIS FEATURE SO THAT THE OVEN WOULD WORK.
Feb 24, 2008 | Black & Decker TRO210 Toaster Oven with...
Toaster Ovens Logo
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Raviteja
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
