Question about Nikko Stirling Platinum Nighteater 3.5 - 10x42 mm 1 Scope
Operation manual for nighteater 3.5-10x42 scope
Where do I get a operation manual for this scope
Need owners manual for lowrance model# elite 4 hdi
here you go
[PDF]Mark-4 HDI & Elite-4 HDI - Lowrance
https://www.lowrance.com/.../Lowrance.../ELITE-4_HDI_OM_EN_988-10576-001_w....
Installation & Operation manual. Mark-4 HDI & Elite-4 HDI. Operation manual ... Lowrance Mark-4 & Elite-4 HDI ...... Selects the transducer model attached.
[PDF]Elite-4x HDI - Lowrance
www.lowrance.com/.../Lowrance.../ELITE-4X_HDI_OM_EN_988-10586-001_w.pdf Installation & Operation manual. Elite-4x HDI. Operation manual .... 4. Basic Operation ' Elite-4x HDI. Selecting Pages. To select a page, press the keypad in the direction of the desired page and ..... Selects the transducer model attached to ...
[PDF]Mark-4, Elite-4,5, 7,9 Operation Manual - Lowrance
https://www.lowrance.com/.../Lowrance.../MARK_ELITE_SERIES_CHIRP_OM_EN_98...
... Elite-7 & Elite-9. Operation manual ... NOTE:This manual covers Mark-4, Elite-4, Elite-5, Elite-7 and Elite-9 units. As a result ..... Selects the type of transducer model attached to your unit. ..... HDI 83/200kHz (Medium/High CHIRP. 83/200kHz ...
manual for lowrance model elite 4 hdi Google Search
Oct 21, 2017 | Lowrance Boating
Where can i find a owners manual. i bought it cheap from a friend but have no manual to it
http://www.airrifleshop.co.uk/Airgun%20manuals.htm
Has some gamo manuals not the specific one you want but has all the important info for safety and operation plus zeroing if its a parts diagram you want look at the following link
http://www.aceros-de-hispania.com/MANUALES-DESPIECES/DESPIECES-CARABINAS-GAMO/despiece-silent-stalker.jpg
Mar 29, 2015 | Gamo USA Gamo Silent Stalker Whisper...
Galileo Astronomical Telescope D=118/F=1000mm manual
Doubtful you will find the exact manual as these are made in India. However this is very similar in operation and assembly to several other brands. Take a look at this video-
http://s7d5.scene7.com/s7/uvideo.jsp?asset=Orion/How-to-Assemble-Orion-SpaceProbe-130ST-EQ-Part1-VID153-2-12i-AVS&config=Orion/Universal_Video1
These are simple to assemble and use once you have seen it done. Try to find a local Astronomy club whose members will help you with the scope.
Jul 21, 2014 | Optics
I have an omark 44 drilled and tapped for scope have fitted a nighteater 8-32x44FC scope which runs out of elevation adjustment at 600 meters target,i want to shoot to 800 meters target,what can i do.
all you can do to raze the point of aim is to jack up the eye end of the scope with 35mm film strips or some thin shims,,,three strips of film will pick up the point of aim by miles
Nov 30, 2010 | Weaver 1" Rifle Scope Mount Rings 49719...
Hi, I have a tasco rifle scope 3-9,40,around 1976 vintage.numbers on the scope are 628 tr.looking for an operating manual
I have an operating manual for this scope. I can have it copied and send it to you if you will pay for my costs. Probably about $10.00 with gas and all.
Jan 03, 2010 | Tasco Hunting World Class Scopes Standard...
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
Nov 11, 2009 | Tasco PH39X40D 3-9x40 Pronghorn Riflescope...
Nikko Stirling Platinum Nighteater 3.5 - 10x42 mm 1 Scope Logo
41 people viewed this question
Top Nikko Optics Experts
NOEL
NOEL
ray gallant
james laughton
james laughton
Are you a Nikko Optic Expert? Answer questions, earn points and help others
