Question about Apple Iphone A1387
How to extend ring time
Ring time is only 4 rings not long enough to answer call
Phone rings 10 times before answering Mach answers it ignores my request for 4 rings
read you instructions and it will tell you how to set the ring time.
May 05, 2015 | Uniden Cordless Phone
How do I extend the ringtone time of incoming calls on binatone lifestyle 1910
Most of the newer phones have a feature that quiets the ringtone when you touch the phone or move it. You can deactivate this feature in the settings menu. I hopes this helps you..
Nov 25, 2014 | Binatone Lifestyle 1910 Twin Cordless...
How to extend ring
To extend the number of rings before your phone goes into the answer message option, change the settings for Answer delay option as described below.
You can set number of rings before your phone answer message kicks in. You can set answer message to begin after 2, 4, 6 or 8 rings.
1. Press <Menu> and up down to select ANS Machine
2. Press <OK> and <up/down> to select TAM Settings
3. Press <OK> and <up/down> to select ANSWER DELAY (OPTIONS: 2, 4, 6 OR 8 RINGS)
4. Press <OK> and <up/down> to select to select desired delay.
5. Press <OK> to confirm.
Aug 18, 2014 | Binatone Lifestyle 1910 Twin Cordless...
Extend ring time
this feature is set by your carrier. Call customer service and ask them to extend rings to 6 - 8.
Jul 26, 2014 | Motorola Cell Phones
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
Set number of rings
If you have the Digital Answerer in White with Extended Recording Time TAD-3808, then slide the Ring Select switch on the right side of the unit to the desired number of rings. TS = toll saver and answers after 2 rings if there are new messages; , otherwise, it will answer after 4 rings.
All of the Radio Shack answering machne manuals can be accessed here: http://support.radioshack.com/productinfo/ProductResults.asp?Name=Telephone_Answering_Devices&ID=002004 .
For the 3808, see http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-3808&Name=Telephone%20Answering%20Devices&Reuse=N for the manuals.
I hope this helps.
Jan 15, 2011 | Radio Shack 3808 Digital Answering Machine
Answerer responds after only 1 or 2 rings.
I am an 83 year pld and I have a ge answering machine and i want to extend the number of rings from 4 to 6
the model number is 29875ge1-b
the serial number is 61794103
it is a digital messaging system
other info on back of machine is atlinksusa inc
Feb 08, 2009 | GE 29875GE2 Digital Answering Machine
Increase numbers of ring
If the machine won't go past 4 rings (which it should somewhere in the answering machine settings menu) you could always change your greeting to a message that tells the caller to wait a few more moments for you to answer, while you get to the phone....
Jul 15, 2008 | Uniden TRU8885 Digital Answering Machine
Brother Fax T86
Try this... 1. Press Menu/Set 2, 1 2. Press <-- or --> to select Ring Delay, then press Menu/Set 3. Press <-- or --> to select how many times the line rings before the machine answers, then press Menu/Set when you see the desired ring number. 4. Press Stop to exit. Hope this helps.
Jun 14, 2007 | Brother FAX 8650P All-In-One Laser Printer
Apple Iphone A1387 Logo
474 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
