Question about Nokia 6111 Cellular Phone
When i switch on my phone Nokia6111it says unable to switch on PTT Check settings,Then in seconds it switches off.What should i do?
When i switch my phone on it switches off the second i switch it on so please help me i can't use it anymore please help
  • 749 Answers
Ever changing the battery, try plugging in the charger then switch it on, if it does turn on, it might have a dead battery already, borrow same battery to someone and test it on your phone! if it still gives you same problem, then your phone have a problem on its power circuitry! (here it needs repair)
Posted on May 21, 2009
  • 6,784 Answers
Ok, i am assuming that the cell battery is fully charged so, if this is the case, you are experiencing a main board fault. you can pull the battery for 5 minutes and replace the batt is the phone after the five minutes. if the phone continues to react in this manner after the five minutes without the cell batt, this will confirm main board failure and you will need to replace the mani board in this phone or purchase a new unit.
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
Unable to switch push to talk
14. Push to talk Push to talk (PTT) is a two-way radio service available over a GPRS cellular network (network service). You can use PTT to have a conversation with one person or with a group of people (channel) having compatible phones. While you are connected to the PTT service, you can use the other functions of the phone. To check availability, costs, additional features and to subscribe to the service, contact your service provider. Roaming services may be more limited than for normal calls. This feature may not be available, depending on your phone. For more information about signing up for the PTT services and the usage, contact your service provider. To connect to the PTT service, select Menu > Push to talk > Switch PTT on. LOOKS LIKE YOU HAVE TO SUBSCRIBE TO USE IT! hope this helps.
Oct 08, 2012 | Nokia 6300 Cell Phone
My motorola l6 when i switch on it shows ptt services off and all switches are locked how can i switch on the ptt services on ?
It means the PTT switch button gets stack or damage that's why other keys are not working.
If this PTT switch is useful for you, you need to consult a mobile service shop near you for a switch replacement. BUT
If this is not helpful, you can remove it by yourself. just follow this procedure.
(You need a T6 precision screw driver or any tool that can release the screw and a soldering iron to remove the ptt switch)
1. remove the battery cover and the battery pack.
2. release the 4 screws located at the upper portion at the back.
3. remove the plate cover.
4. there are 2 flex connector at the top which lcd is connected and at the bottom which keypad/simcard is also attached. Also the anthenna and the camera is insert prior on the location.
Release them with care.
5. lift up the entire board module.
6. locate where the PTT switch is attach (right side when facing the front phone) then remove it with care by using a soldering iron until the 4 connector of the ptt switch is remove.
7. now assemble the phone and be guide with the pattern on how it was dismantle.
Now check it if other keys is working now, please reply if there is still a problem
good luck... and thank you for visiting Fixya.
Jul 02, 2011 | Motorola Mobility L6 Cellular Phone
In my Nokia 3230, The message displaying again & again that "unable to switch ptt on chek ptt settings". what is the solution to stop this message
PTT means Pus to Talk.May be your Push to Talk button is damaged or stuck.PTT button situated in right side top .You can reset the phone settings by restore factory settings.Default code is 12345.
Sep 29, 2010 | Nokia 3230
Unable to switch ptt on check setting
ITS NOT A PROBLEM OF YOUR PHONE AT ALL YOU SERVICE PROVIDER MAY NOT HAVE THE FACILITY OPERTE PTT FACILITY IN THE NETWORK IF THE FACILITY IS AVALIBLE CALL THE CUSTOMER CARE TO SEND THE SETTINGS FOR PTT AND WHEN YOU RECIVE IT SAVE IT TO YOUR PHONE AND RESTART THE PHONE AND YOU CAS USE IT
Oct 18, 2009 | Nokia 6020 Cellular Phone
NOKIA 6085 SHOWS PTT SETTINGSAND SWITCH OFF
u send a solution 4 problem but there is nothing to read
nokia 6085 shows ptt setting and switch off
Oct 16, 2009 | Nokia 6085 Cellular Phone
Unable to switch on ptt in my nokia 3110c
push to talk was earlier introduced by tata tele and hutch it is available in tata kyler mobiles which was import by tata from japan and america,but ptt is still in controversies in india due to technological reforms or u may say our own elected illiterate ministers.........so wait for ptt to be lanched by all telecom companies
Apr 01, 2009 | Nokia 3110 Cellular Phone
Motorola T6550 pair.
I can see where this feature can seem somewhat inconsistent. But if you think of it like a phone ringing, it is easier to understand. Once you have answered the phone, the phone stops ringing. And the person who called you never experiences a ring on their end.
VibraCall® Alert
Page 26: VibraCall is a vibrating alert that notifies you that your radio is receiving a message. This is useful in noisy environments. When the alert is on, the radio
vibrates once every 30 seconds when you receive a message on the channel and
code you set.
• To turn vibrating alerts on, press menu until the vibrating radio symbol is displayed, then press the plus (+) button to display the letter Y for Yes.
• To turn vibrating alerts off, press menu until the vibrating radio symbol is displayed, then press the minus (-) button until the minus symbol (-) is displayed.
Dec 10, 2008 | Motorola Talkabout T6550 (7 Channels)...
Pls my phone has problem
the ptt switch is stuck up that's why your keys don't work and the message you mentioned always appears.. have it brought to a technician
Dec 25, 2007 | Nokia 6070 Cellular Phone
Nokia 6111 Cellular Phone Logo
163 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
