Question about NextBase SDV-17 Portable DVD Player
My next base dvd player nb-320 suddenly changed the image to black and white after several seconds of viewing
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
PANASONIC TH37PX POB DVD ONLY PLAYS IN BLACK AND WHITE
alot of times u need to change the settings in your dvd player it has 2 video setting it will have 3 options pick auto and u will get colot its in your dvd meue not the tv....................
Feb 08, 2013 | Panasonic TH37PX60B TV
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Color problem
Check the cables connected to the back of the projector. reinsert the cables a few times to get a good contact. Jiggle the connection at the projector to see if there is a bad connection, do this while viewing the image on the screen. If everything is good and no response to the connections, It might be the main/input board is bad and will need replacement.
Aug 16, 2008 | BenQ PB6100 Multimedia Projector
My Hyundai DVD player plays DVD's in Black and White or in a greenish tinit. Freeview, videos all okay. Any ideas?
On the DVD Player, there maybe somewhere where you can change the output to the television (Scart) from RGB to Component or Composite-mode.
RGB causes some displays which cannot handle the RGB signals to black and white.
I hope this fixes your problem.
Finally, some TVs designed for PAL cannot handle NTSC discs played through them. It causes the display to also go Black and White. If this is the case there is nothing you can do except change the display/TV.
Don forget to rate.
Mar 17, 2008 | Hyundai ImageQuest DVD 320 A DVD Player
Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
Jul 01, 2007 | JVC XV-S302 DVD Player
NextBase SDV-17 Portable DVD Player Logo
Top NextBase Televison & Video Experts
Electro Med Services...
Are you a NextBase Televison and Video Expert? Answer questions, earn points and help others
